Old 11th August 2010, 03:41 PM
davidimurray's Avatar
Default Sierra ignition barrel and current
Just doing some more tidying up and sorting out on my wiring diagram. I calculate that with my circuit, the max current that will be drawn through the ignition barrel in position 2 is 50Amps. This sounds a lot to me - can the ignition switch take that sort of current?
I've worked it out by taking the fuse ratings for -
20A - Indicator,Reverse & Handbrake Lights
10A - LHS Sidelights, Tailights & Number Plate
10A - RHS Sidelights, Tailights
10A - Brake Lights & Dash
On the permanent live side of things, the load is 120A max excluding the starter.
Old 11th August 2010, 04:06 PM
drury318 drury318 is offline
On a Sierra loom and fuse box there is a black ign relay, you will find it has 2 normal size terminals and 2 really big ones, this will take the current ok if you put one in the circuit, Dennis.
Old 11th August 2010, 04:27 PM
Ah ha - Cheers Dennis
Looks like its time to incorporate another relay and update my wiring diagram.
Old 11th August 2010, 05:00 PM
David,
You could do as I talked about in your other thread and wire the side lights to a permenant live as per the original Sierra. This would remove 20A from your load and mean you do not need the additional relay.
Old 11th August 2010, 05:25 PM
Enoch Enoch is offline
side lights don't take anywhere near 20 amps (4 5 watt bulbs plus the panel lights)- more like 5 or 6. Most of the load will come from a live going direct to the fuses and then to relays.
Enoch
Old 12th August 2010, 08:32 AM
In between chopping up material for suspension bushes I braved to dig the sierra fuse box out of my big bag of wires. Had a look but couldn't fina a big black relay. My Sierra was an 87 GL - anyone know if they had them - will check the haynes diagram this evening.
Davedew - that is one option. My only reluctance is that when the car is parked up - any passer-by could switch the lights on.
Enoch - assuming all the side lights added up to 6 amps, that leaves 36amps to take through the switch gear.
One thing I have yet to check is the size of the wire going to the switch as I'm guessing this would be a good indicator of capacity. I'm currently leaning towards fitting the relay as it then keeps all the high current carrying wires out of the cockpit.
