Old 12th August 2010, 01:26 PM
aerosam's Avatar
aerosam aerosam is offline
Default What spring rates???
Hi guys,
I'm almost ready to go ahead and buy my suspension, I've been putting it off for ages as it costs so much.
I know what length dampers I need, but I haven't a clue when it comes to what poundage springs would be appropriate.
The engine is a little heavier than normal, at 146kgs and at the rear I'm using semi trailing arms with an anti-roll bar, if this make any difference at all.
Oh, and the car is going to be used on track only, so handling takes a major precedence over ride quality, as most tracks will be fairly smooth anyway.
Old 12th August 2010, 01:45 PM
antonia800 antonia800 is offline
speak to GAZ based in essex found them verry helpfull in every way one comment on your exhaust manifold, it dosent help the flow of gasses i would check that this will be ok as heat build up in the engine could cause disaster performance = flow in and out great idea using the bmw v8 tho
Old 13th August 2010, 04:22 PM
tex tex is offline
depends on your car weight overall really - car engined car - try 300-350 front 200 - 250 rear. bike engined car 200 front - 150 - 200 rear
Old 14th August 2010, 09:27 AM
Remember the poundage is only one of the TWO things you need to know, the other is the unfitted length.
Old 14th August 2010, 03:59 PM
grumpy locost grumpy locost is offline
Default spring weights
Originally Posted by aerosam View Post
Hi guys,
my locost which is ten years old and weights 540 kgs has front springs of 225 and rears of 160 but remember the rear springs on a locost work vertical and not at a angle like the roadster
Old 14th August 2010, 04:49 PM
My Roadster has 350lb up front & 250lb at the rear , using a 1.8CVH engine.
Spuds is the same spring rates too, & it handles like its on rails , with just the "right" amount of sprung weight when he throws it into the corners on a trackday etc.
Old 14th August 2010, 05:25 PM
tkpm tkpm is offline
i'm using the same as the Andy's running a Pinto
Terry
Old 14th August 2010, 06:48 PM
Don't forget, he needs the unfitted length as well! Poundage is useful but it's not all the story.
Old 14th August 2010, 08:24 PM
aerosam's Avatar
How do I figure that out?
I think I might just take Antonia's advice and call GAZ on Monday.
