Old 22nd August 2010, 04:01 PM
chrisxr2 chrisxr2 is offline
Default Car not running right advice
Right car is constantly misfiring/ hesitating (Sounding like a tractor) throughout the rev range. Sometimes dieing at junctions, sometimes stuck at between 2500 and 3500 revs no changing down or anything makes a difference you have to pump the accelerator just to keep momentum at all. have changed the fuel filter, cleaned the carb and jets to no avail, the car seems fine when first driving then as it gets warmer gets worse. Has not been right sice it died on the way home a few weeks ago. Think maybe the rolling road is my best tool to use but wonder if anyone has any ideas first?? Very frustrating 44 mile round trip to lincoln today. All the obvious things have been eliminated. I am sure it is something simple but what else can people suggest??
2.1 pinto with twin webers. I dont think enough fuel is going through when you watch the fuel filter, any advice would be greatly appreciated. Car has not had any issues for previous 7000 miles so no clues there.
Old 22nd August 2010, 05:14 PM
David_17's Avatar
David_17 David_17 is offline
Could it be an ignition problem? plugs/leads etc. I don't think fueling would make it sound like a tracktor, that sounds more like a misfire. Although all your other symptoms do suggest fueling.
*updated 7/6/11*
Old 22nd August 2010, 06:34 PM
Davey's Avatar
Davey Davey is offline
Four things are required for internal combustion to work: compression, air(oxygen), fuel and a spark to ignite it all. This means there are only a few possibilities that are causing your problem.
1. Compression, do a compression test, this will show up any problems with valves sealing and or piston rings/bore wear. Not the most likely culprit for the problem you describe.
2. Air, is the air filter clean? If the engine can't get enough, or alternatively gets too much(manifold gasket or carb gasket leaking perhaps?), it will be difficult to start and won't give good performance, possibly to the point of what you describe.
3. Fuel, is the engine getting enough? A poorly fuel pump or blocked fuel filter can lead to fuel starvation giving symptoms like you describe. Also blocked jets in carbs can cause similar problems.
4. Spark, is the coil performing properly? Are the HT leads in good condition? Is the timing set correctly?
These are the basic steps to sorting your problem. My guess would be ignition problems, either a coil failing or timing out by a significant margin but it could just as easily be a leaking manifold gasket.
D.
Old 22nd August 2010, 06:49 PM
Some have had problems with muck in the tank blocking filters on more than one occasion.
Worth a try.
Old 22nd August 2010, 07:14 PM
Enoch Enoch is offline
Check that air is able to get in to your tank. If you are pulling a vaccum as the fuel is pumped out it will cause fuel starvation, which could give a problem like you are describing. Fast way to check is to undo the fuel cap when the car is playing up. You will hear air being sucked in to the tank and the running will return to normal if this is your problem.
Best of luck with fixing it.
Enoch
Old 23rd August 2010, 05:57 AM
frankie boy's Avatar
Hi chirs
sorry to here your having some truble with the car.
It sounds like there is blocked ideil jet. This is way when you give it beans it runs. The ideil jet as it is called isn't for keeping the car on tick-over. The jet is for second progesion it's the most important jet. Give me a call when you get a chance and I will try to talk you though it.
my Roadster
Old 23rd August 2010, 10:36 AM
Default Thanks frankie
thanks frankie, thinking maybe fuel breather pipe also to be checked, all 4 jets in both carbs been removed and cleaned so they are out of the equation (They werent blocked) tried a few things thought i would ask if the xombined masses brainpower had any ideas.
Misfiring across the full rev range now.
Old 23rd August 2010, 02:33 PM
Twin's Avatar
Twin Twin is offline
What sort of choke set up do you have? It may be playing up if it's only after the engine is warm!
Twin
CSF £857.19
Twins Roadster
