Old 10th September 2010, 05:27 PM
will_08 will_08 is offline
Default Sierra Donor Q's??
Hey guys,
couple of questions regarding my donor. I have a 1.6 sierra donor that i did want to use to get an age related plate. but my friend has a 2litre with stage 3 head on it so naturally i want it. should i use it will i end with a Q plate though?
Also in my garage i have the potential death hazard that is the complete rear axle from my sierra. exactly like page 28 of the book. how much of that can i get rid of? i know i need the diff but what about the rest?
any help much appreciated Will
Old 10th September 2010, 05:42 PM
David_17's Avatar
David_17 David_17 is offline
I think you'll need the donor engine to get an age related plate, if you want one you'll have to swap after iva.
As far as axle goes, you need to keep the diff, driveshafts, rear drum back plates and drums. Dont forget to keep the bolts that connect the prop and diff together, as i've been told they're a nightmare to find a supplier.
Dave.
*updated 7/6/11*
Old 10th September 2010, 10:41 PM
james3004's Avatar
i'm not 100% sure but i believe that you can still get an age related plate if you use a different engine, as long as all the other parts are from the donor.
As for the rear axle you need the diff, driveshafts and brakes from it the big black bent tube type thing can be disposed of
--- James ---
IVA passed 20 June 2017
Flickr Album
Old 11th September 2010, 08:58 AM
That is certainly my undterstanding of the situation James
Age related plates are awarded on a points system .... In theory, you can still get an age related plate without using the engine, provided all of the other major components are from a single donor & you have documentation to prove it.
At some point you will need to provide proof of your engines date of manufacture.
Having said all of that, some local DVLA offices seem to work to their own set of rules
Old 16th September 2010, 09:08 PM
Thanks for all the replies guys, my friend has suggested something that never crossed my mind. Cant i just tell them ive put a 2litre in the sierra that as far as they are concerned is just sorned?
Cheers Will
Old 16th September 2010, 10:42 PM
Coozer's Avatar
Coozer Coozer is offline
Send the V5 back with the new 2L engine number on it....
My Sierra donor had a 1.8 zetec in it
MNR Vortx Build Diary
www.mymnrvortx.blogspot.com/
