Old 20th September 2010, 08:25 PM
shh120m's Avatar
shh120m shh120m is offline
Default how to get hub nuts off
hi guys, just started dtripping my axle, im having problems with the hub bearing nuts. Ive cut the collar off and meted away the plasticy stuff but the nut wont budge no matter how much heat and sweat i put into it.
Has anyone got any tips?
thanks
nathan
Old 20th September 2010, 08:33 PM
David_17's Avatar
David_17 David_17 is offline
You don't need the hub nuts off if you've got rear drums.
*updated 7/6/11*
Old 20th September 2010, 08:35 PM
One is reverse thread.
They are done up RFT.
Old 20th September 2010, 08:37 PM
tkpm tkpm is offline
i undid mine while the hubs where still on the donor
Terry
Old 20th September 2010, 08:45 PM
Coozer's Avatar
Coozer Coozer is offline
This was my solution...
You than put a length of smaller section box, or a bar through the short bit there, stand on it and then you can undo them no problem. Its like that so's you can swap it over to help tighten and also to undo the opposite side.
Hope that helps,
MNR Vortx Build Diary
www.mymnrvortx.blogspot.com/
Old 20th September 2010, 08:54 PM
gaz05 gaz05 is offline
I've just got the back end home and didn't have a chance to loosen the back nuts. Done it tonight with a 3/4 drive socket,large toggle bar and a large hammer. Just stood on the drum and kept shocking the toggle bar with the hammer. Just took a couple of minutes. The n/s nut (LH) is left hand thread.
Total cost so far
Materials £3,150
Tools £855
Old 20th September 2010, 09:54 PM
shh120m's Avatar
cheers,
Il have another go tomorrow night once iv found a long tube for some extra leverage.
