Old 21st September 2010, 07:13 PM
David_17's Avatar
David_17 David_17 is offline
Default Throttle cable.
Found these on VWP http://www.vehicle-wiring-products.e...ntrolcable.php
How do i figure out the inner and outer lengths for my throttle cable?? Is there any easy way, or is it just guess work?
Cable will be connected to gsxr600 throttle bodies.
*updated 7/6/11*
Old 21st September 2010, 08:38 PM
snapper snapper is offline
Inner cables are usually longer than outers
You can cut the outer to length fit the inner then cut off the excess at the most convenient end.
It's no different to fitting a new brake cable to your push bike
Old 21st September 2010, 08:44 PM
mark mark is offline
I actually used a brake cable off a mountain bike on my bike carbs, done 1600miles and its still like new.
Just cut it to whatever length you need.
Old 21st September 2010, 09:43 PM
David_17's Avatar
Ah right, so just order it slightly longer then chop to suit. Cheers guys
*updated 7/6/11*
