Old 25th September 2010, 11:55 AM
mikemph mikemph is offline
Default tunnel mods for 2.0 duratec
Does anyone know if the tunnel needs to be modified to fit 2.0 duratec and MT75? Any idea of the measurements?
Old 25th September 2010, 12:23 PM
The engine will be pretty much irrelevant to the tunnel, but the MT75 gearbox will require a wider tunnel, it's all been worked out and is on the furum here, somewhere, I'll see if I can find the link
There you go, scroll down the page a a bit
http://www.haynes.co.uk/forums/showthread.php?t=2430
Old 26th September 2010, 06:01 PM
big_wasa's Avatar
big_wasa big_wasa is offline
More to the point you wont be able to mount the Duratec to an mt75 unless you know better ? In which case please share the info on how.
Nowt again.
Old 26th September 2010, 06:12 PM
That's a very good point! He needs a type 9 with an adaptor bellhousing, or some kind of adaptor plate for the MT75
Old 27th September 2010, 03:23 PM
I was going to make up a plate to mate them together. I was worried the type 9 would not be upto the job? I heard that 150ish bhp was the limit
Old 27th September 2010, 04:00 PM
I thougt Coozer had a Duratec in his Indi.
