			 Hi all,
	I've got a rover 3.5 litre v8 from a Discovery that I'm planning to use in my roadster. As it came from a Disco, the LT77 gearbox is the 4wd version. I managed to get hold of an R380 from eBay, but it must have come from something else as the input shaft is way too short. I'm trying to swap in the input shaft from the LT77 that came off, but the gears are different sizes. I can't figure out how to get the gears off each of the input shafts to swap them over. Has anyone done this, or can point me in the direction of any info? I've got the overhaul manuals for each gearbox, but they don't really talk about the input shafts. Cheers, KEv.  |
			 Gear on the input shaft may not be removable as most I have dealt with are part of the shaft,specialist 4x4 repairer is probably your best bet for info.
	Cost : Little as possible. Thanks : To those who by their generosity my build has progressed. Its a handmade sports car not a flaming kit car !!! If at first you dont succeed,avoid skydiving... No parachute require to freefall,only if you want to do it twice.  |
