Old 1st October 2010, 10:31 PM
Locky Locky is offline
Default Which chassis?
I am looking to use an omega as a donor car which is wider than a sierra as used by Chris Gibbs. But the chassis built by Ron Champion is wider, so am i better off going for the wider chassis or the narrower chassis?
will it look odd? also im pretty certain there would be less strain on the wishbones if they are on the wider chassis as they would be shorter.
Thanks for any info.
If it has breasts or wheels it will give you problems.
Planning Stage
Old 1st October 2010, 11:21 PM
dan_g8 dan_g8 is offline
I thought the haynes roadster was 2 inches wider than the Ron Champion locost?
Old 1st October 2010, 11:27 PM
my mistake it is
Planning Stage
Old 1st October 2010, 11:30 PM
Have you looked at the McSorley chassis which is 4 inches wider?
Old 2nd October 2010, 07:32 AM
The Locost and Mcsorley use a solid rear axle, not IRS
Old 2nd October 2010, 09:00 AM
You could use a McSorley 442 chassis with a DeDion back axle. Strip the hubs from the Vauxhall uprights,it might be easier than trying to match up to the multi link mounts. Although I'm not too sure if thats correct seeing that it been a long time since I've worked under one.
