Old 25th October 2010, 10:38 PM
tkpm tkpm is offline
Default Latested Version of IVA
This is version 5.02 updated 18/10/10
http://online.businesslink.gov.uk/Tr...rsion_1010.pdf
Some light reading while i'm on my hol's
Terry
Old 25th October 2010, 10:44 PM
Give us the lowdown on the changes when your done
Old 26th October 2010, 09:19 AM
eSteve's Avatar
eSteve eSteve is offline
Default IVA manual changes 5.00 (June 2010) to 5.02 (Oct 2010)
tkpm,
do you get some sort of notification when the IVA manual is ammedend or is it by chance that you notice it's change, or is it always ammended this time of year?
I've just had a look at the revisions, searched the PDF for 18/10/2010. These are the sections that have changed.
Manual with Basic Requirements
13B Anti - Theft / Alarm
Add Thatcham Recognised Installer installation report to list of acceptable evidence
36 Heating System
Note 1 amended to allow small water drain holes in heater intake system.
Previous version (5.0) read:
Note 1: The air intake must not be positioned near the vehicles exhaust outlet or draw air from within an engine compartment etc.
New version (5.02) reads:
Note 1: The air intake must not be positioned near the vehicles exhaust outlet or draw air from within an engine compartment etc. Holes to allow water to drain out of heater intake system into the engine compartment are permitted provided that the total surface of holes amount to less than 1% surface area of the heater intake aperture.
Normal IVA Requirements
13A Anti - Theft / Immobiliser
That's all, so not anything to cause any concern.
Regards,
eSteve
Old 26th October 2010, 09:39 AM
eSteve it was by chance that i found out that the manual had been updated.
Terry
Old 26th October 2010, 09:53 AM
eSteve's Avatar
I had imagined that there might be some mechanism for interested parties to be notified of changes, but as I see we just have to rely on good fortune to find out. Thanks for letting us all know
My first thought was that maybe they updated it at certain times of the year, but that isn't the case since the revision dates seem to be scattered throughout the year.
I suspect someone may have written an application that would monitor a web page for changes. I may have a look in to this and see if there is an open source one. It could be left watching the VOSA page that has the link to the IVA manual waiting for changes.
Enjoy your holiday.
P.S Forgot to add that the error with the bookmarks appears to have been correct. They used to go a bit wonky after section 9A
Regards,
eSteve
Last edited by eSteve : 26th October 2010 at 09:57 AM. Reason: Added fact that bookmarks have been corrected
Old 28th October 2010, 09:35 AM
eSteve's Avatar
Default Getting notified of changes to IVA manual
Further to my previous post:
I have found a site (of which there are many) which enables you to monitor for changes to a web page.
It is here: http://www.changedetection.com/
You provide the URL of the page you want to monitor for changes and it will send you an eMail whenever a change is detected.
I've set up two monitors:
One on the local paper's website. This is a test, since I know this site changes frequently. Sure enough I had an eMail this morning telling me it had changed and a link to a change log. So it does appear to work.
The other monitor is to the site containing the link to the current IVA pdf (http://www.businesslink.gov.uk/bdotg...type=RESOURCES). The name of the pdf is related to its version, so the hyper link to it will change when the IVA document is up issued, hence the page will change and (hopefully) www.ChangeDetection.com will notify me of the change. Of course I will get notified of other changes on the page to, but I hope there will not be to many 'false alarms'.
Of course, the IVA manual does not change too often, so it might be a while untill this is proven to work. I'll report back if it does. Then we will have a mechanism of being notified immediately of IVA manual changes.
I really should have something better to do, shouldn't I?
Regards,
eSteve
