Old 18th November 2010, 08:48 AM
Question Oil pump priming
I've just filled the engine with oil & thought it would be best to circulate some of it through the system seeing as it hasn't had any in for about 8 months now.
In total I must have cranked the engine for 5 minutes, and still have not got any oil showing at the filter.
When I altered the pickup & sump I cut 25mm from each part. Have about 3-5mm of clearance between the pickup & bottom of the sump.
I've tried squirting oil in through the pressure relief valve, oil filter ports, still nothing.
What have others done? Would you just fill the filter & start the engine and see if oil light goes out?
Pain having to split engine & box again to get to the rearmost sump bolts.
Old 18th November 2010, 12:17 PM
mark mark is offline
Does the oil pressure warning light go out?
All i have done for a first start is disconnect coil pack and fuel and turned over until the light went out then reconnected fuel and spark and fired it up
Old 18th November 2010, 01:15 PM
Haven't got the wiring sorted yet. Just connecting starter straight to battery. Even with oil filter off when cranking no oil comes out, so I wouldn't expect the light to go out.
Old 18th November 2010, 05:15 PM
DaddyA's Avatar
DaddyA DaddyA is offline
Dave,
not critising your welding but you did make sure there was no leaks from your pick-up before fitting it?
ie - blank it thenfill it with white spirit and see if it seeps through?
Its alot easier to suck air than cold oil!!
Probably doesn't help at this stage.
Daz...
Old 18th November 2010, 07:46 PM
Perhaps the pump is not airtight and cannot suck the oil in? Perhaps it's worth feeding some oil into the pump through the filter hole?
Old 18th November 2010, 08:13 PM
If it is towable take the plugs out and tow it,rig up a bulb to the oil pressure switch.
All you need is a live to live feed to bulb and the other to the switch as the rise in oil pressure breaks the earth and puts the light out.
