Old 13th January 2011, 07:13 AM
Default Engine Heater Hose - Help
I am using the Cologne V6 2.8I Engine.
I have removed the heater matrix from the orginal Sierra and and I have linked the flow and return hoses. Is it likely to cause any harm to the engine if I remove this link hose and cap it off with an ali plug on the top and bottom of the engine? I assume its just a secondary hose off the radiator circuit, although it does not appear to run via the thermostat.
Any help appeciated as the exisiting pipe is to near the braided fuel lines and I would like to remove it this weekend in preparation for the first test drive!
Old 13th January 2011, 08:36 AM
should be fine without it. blocked them off on the pinto without adverse effects. the only reason it bypasses the thermostat is so that the heater in the car works before the thermostat opens up. have also blocked it off on the new engine.
My Pictures
Old 13th January 2011, 01:48 PM
The heating is controlled by a valve, so when the heater is off the flow is blocked.
Old 13th January 2011, 03:12 PM
find out how the orignal cars heater matrix was controled (air flap or valve)
some require flow all the time trough the matrix to get the same cooling(ballanced) to all the cyl's
the way i would do it and works is block off if it has a valve controling the coolent flow if not link the input to the output and place somthing simple like a washer or thiner pipe to ristrict the flow to simulate the matrix's flow rate
thinking about it this would work for both types and would remove the risk of air pockets
Old 13th January 2011, 05:33 PM
That is not correct.
Sierras have flow through the matrix all the time, so when someone says " Make sure you have the heating on hot when filling the system" it's not going to make a blind bit of difference.
Old 16th January 2011, 09:54 AM
snapper snapper is offline
I just ran a simple 16mm hose between pump and inlet manifold adaptor, no restrictor needed, the only thing I added was a bleed T
