Old 13th February 2011, 12:10 PM
Deanno's Avatar
Deanno Deanno is offline
Default To Pulse or not to Pulse?
Currently I just happen to be welding 25mm by 2mm thick box in work for missile launcher trolleys and in certain places i have to pulse it rather than do a run.
just so i know when it come to my chassis assembly.
I know the pulse does not give you as much heat and penetration.
Just thought id ask what your preferred methods are?
Dean
(under construction)
South Wales Kit Car Club
WWW.HELPFORHEROES.ORG.UK
XBox Gamer tag: D34NNO
Old 13th February 2011, 12:20 PM
shh120m's Avatar
shh120m shh120m is offline
What's pulsing? Sorry mate I'm a bit thick
Old 13th February 2011, 12:26 PM
Why are you having to pulse on 2mm material what are you using MMA MIG TIG? If you have the heat/amps set correct and the correct feed rate or filler rod you should have no problems getting a run, I MIG all my chassis and they are 16gauge. The only material I pulse is 0.8-1mm car panels when I'm using MIG.
Old 13th February 2011, 03:35 PM
Deanno's Avatar
I'm using Mag/Mig the only reason i was pulsing was for awkward joints.
Thanks for your input.
Pulsing is where you blip or zap the trigger so you are doing small spots not a constant run.
regards
dean
Old 13th February 2011, 06:34 PM
I would normally go for a single run Dean.
If trying to to fill wide gaps you don't really have any alternative to trigger blipping .... Well that is bar, trying vertical down run
You can get some decent penetration by pulsing if you up the current a fair bit ( A bit like you should for a nice hot tack weld )
Is there a particular joint that is causing you a problem ?
Old 13th February 2011, 07:50 PM
Deanno's Avatar
no not started yet waiting to move into the new house with a big garage
I'm currently welding missile launcher trolleys in work and i was just wondering.
cheers for all the input
Dean
Old 13th February 2011, 07:51 PM
If you have to fill large gaps it's either because you've blown holes in the job or the prep work is shaby, corner cutting adds to weld failure. This why all of our wishbones tubes are machine profiled with a mill not just cut on the saw and filled in.
Old 13th February 2011, 08:22 PM
Pulse welding is good on carbody steel for obvious reasons,thin metal.
Old 13th February 2011, 09:35 PM
Sorry Phil mate, I have to take exception to that statement if I may !!??
Incorrect welding procedure leads to weld failure .... Shabby fitting joints can be made good with the correct weld procedure ( Obviosly propper prep is desireable )
Your statement also seems to imply that anyone not using a milling machine to cut the compound mitres is somehow doing a shabby job, a gross insult to the folks that know how to use their tools
In my humble opinion, using a mill to cut the compound mitres is like using a sledge hammer to crack a nut
Nothing wrong with a simple hacksaw, bandsaw, compound mitre saw or even a grinder .... It's purely down to the users ability to make correct use of the tool in question !!??
Methinks you could do with a spell working in a dockyard doing some propper plate work, you'll soon learn how to cope with gap filling
BTW
Never had a ship sink yet through a weld failure
Old 13th February 2011, 10:34 PM
Tilly819 Tilly819 is offline
Dean
TIG with a foot pedal is my option in that situation, technically pulse is a machine function that raises and then lowers the current on a set time base to preset maximum and minimum current set points.
the beauty of the tig with the foot control is it allows you to keep an arc going wile you reposition your torch and or yourself to continue your weld.
however if you do not have these facilities at your disposal you current method of what i would refur to as "tacking" or if you can do a small run "stitching" may well be you only option.
hope this helps
tilly
Edit: PS if this is the case, it might be worth upping your current to help get abit more penetration
Welding is like sex, its all about taking your time and getting good penetration
