Old 13th April 2011, 04:28 PM
stan1 stan1 is offline
Talking waxing lyrical
my car chassis and running gear is covered in what i assume is wax oil . what would be the best way to remove this? the resultant parts will then be prepped for paint etc.smoothrite? also ive been reading about cleaning parts using electrolosis . is it ok to drop a complete hub and caliper in? would this affect the bearings seals etc.any help would be appreciated.::
Old 13th April 2011, 06:33 PM
JakeH's Avatar
JakeH JakeH is offline
the gearbox on my sierra was covered in wax oil i used autoglym intensive tar remover, a wire brush and pressure washer to get it off... worked a treat
Jake
Old 13th April 2011, 06:57 PM
probably not wise as the electrolytical reaction will attack good metal as well as rust..... the removal of ions from a rusty part releases the rust flakes which end up as the crud and the clean steel at the other end of the circuit acquires ions and ends up looking knotty......if you can seal off any parts you want leaving alone like bearings/seals good metal etc then yes it will work but risky I think.
Old 13th April 2011, 07:04 PM
js1uk js1uk is offline
Parafin is what you need to clean it off. you use parafin instead of heating it up when you want to spray it..
Old 14th April 2011, 12:52 AM
Talking evil bay
parrafin sounds good . probably because a new wolf air compressor is on its way. thanks for the replys lads.
