Old 19th April 2011, 08:50 AM
David_17's Avatar
David_17 David_17 is offline
Default Had a little oops...
I've been putting off drilling a hole in the top of my alloy fuel tank, for the gauge sender. After finally going for it, drilled the hole and looked through into the tank, and remembered why i wasn't going to drill it at the end...
My tank has baffles in it, and where i drilled the float arm would be undeneath a baffle, so wouldn't work.
Anyhoo, I've drilled another one at the opposite end, which i should be able to fit the float round the baffle.
So my question is, can i tigerseal a square of aluminium over the first hole i've drilled? Will that fail IVA?
*updated 7/6/11*
Old 19th April 2011, 09:29 AM
if it was me i would weld it back up. its the only way to be sure. i dont think tiger seal is fuel proof
My Pictures
Old 19th April 2011, 09:33 AM
David_17's Avatar
I cant weld aluminium And I dont want to take it all out, to get it done somewhere.
The other thing i thought about was riveting a plate over the hole with a cork gasket.
*updated 7/6/11*
Old 19th April 2011, 09:43 AM
Make it into an inspection panel get a larger piece as you sugest an bolt it on with a neoprene / nitrile rubber gaskett ( one o them cant remember whicb is better )
Im fitting an internal pump so i need a large inspection panel so planned this route to fit my pump but im not using ally
Old 19th April 2011, 12:18 PM
snapper snapper is offline
Tiger seal is not fuel proof, ask me how I know!!!
Cork and or rubber if you must, you could take the opportunity to fit breathers and fuel return gubbins.
Old 19th April 2011, 05:42 PM
KAMBO KAMBO is offline
you need some of this "we call it shit in the trade"
http://www.silmid.com/Products/Seala...R1782C150.aspx
