Old 22nd April 2011, 04:46 PM
brainbug007's Avatar
Default Started Putting My Suspension Together
Finally got some of my suspension on today, well chuffed as it makes my roadster start to look like a car The only bit I found a bit confusing was putting the transit drag links into the top wishbones. The book seemed to suggest the locking nut would go on but once the drag link is fully screwed in it sits flush with the end of the thread and I don't have enough thread to put the nut on?? Here's some pictures of where I got to, I think I've done it right but if anyone spots anything let me know!
Old 22nd April 2011, 06:01 PM
John.W John.W is offline
Hi Bb007, if you have a look on page 124 in the book there is a good picture and it shows the nut between wishbone and balljoint.
Regards
John
Old 22nd April 2011, 06:33 PM
gaz05 gaz05 is offline
Do you mean the balljoint taper doesn't go far enough through the mushroom to get the nut on? I got my Balljoints from EDS and my mushrooms from 3GE and they didn't fit either. See this thread
http://www.haynes.co.uk/forums/showt...ght=balljoints
Edit. Crap. Just read your post again and see you're talking about the adjuster lock nut.
Total cost so far
Materials £3,150
Tools £855
Old 22nd April 2011, 07:14 PM
No sorry I'm not on about the ball joints (austin maxi ones), I'm on about the transit drag links and screwing them into the top front wishbone. I'm guessing I just have to screw the locking nut right down the bottom and the drag link itself doesn't screw completely into the wishbone?
Old 23rd April 2011, 08:44 AM
Thats the correct way to do it
thread the halfnut locknut fully onto the drag link thread then fit the drag link into the top wishbone, once you have fully built your car , with all the weight onto the suspension you can then adjust everything to set it up correctly.
Old 23rd April 2011, 09:23 AM
In this photo you can just see the lock nuts between the draglink "knuckle" & the wishbone threaded boss.
hope it helps.
Old 22nd April 2011, 07:19 PM
Yes I was, Ithought that was the nut you were talking about or do you mean the nut that goes inside the mushroom?
Old 22nd April 2011, 07:34 PM
Did you have a look at the picture on page 124, I think that picture confirms what you have just said.
Old 22nd April 2011, 07:58 PM
No sorry, the book is out in the shed. It's not the nut inside the mushroom but one that should go onto the drag link's thread but at which end?
Old 22nd April 2011, 09:09 PM
I made my mushrooms from a diagram on here and the one thing I noticed between the drawing on here and John's mushrooms there is a 10mm difference in the thickness of material ie John's have 30mm thickness of alu for the taper to go through the ones in the drawing on here has only 20mm to go through so I would say you need a longer threaded draglink or have the mushrooms turned down a little 5mm off the top and 5mm from the inside....just my tuppeneth
