Old 15th May 2011, 10:07 AM
aerosam's Avatar
aerosam aerosam is offline
Default Weak Brakes - Master Cylinder?
Hi guys - had my car out on track yesterday, and the brakes were pretty lacklustre. It's all working correctly, stops in a straight line,they're just a bit weak, I really have to stand hard on the pedal.
They are sierra fronts and BMW rears (discs). The rears are huge so power is re-directed forward by a bias control valve. The master cylinder is out of my donor BMW E34 5 series, and it had a hydraulic powered servo, which I didn't use as it was very long and the hydraulics were complex.
So, I'm guessing the unassisted master cylinder simply can't provide enough stopping force. Isn't the roadster normally fitted with a sierra master cylinder without the servo? Is there room for the servo, if required?
I'm thinking of replacing my donor cylinder with a sierra one, with servo, in order to seriously upgrade my braking power. Unless you guys can think of anything else that would be hold the brakes back?
Old 15th May 2011, 10:17 AM
By no means am i braking expert but just by reading what you have said i too would assume its the reason of a non-servo system, i also assume that there is no "spongy-ness" ?
Old 15th May 2011, 10:51 AM
MarkB MarkB is offline
You don't want or need a servo on such a light car, what pads are you using as normal road pads won't take much punishment on a track day they will fade!!!
Old 15th May 2011, 12:20 PM
davidimurray's Avatar
What is the diameter of the E34 master cylinder compared to the sierra one? Have you checked the hydraulic ratio compared to the original sierra setup?
Old 15th May 2011, 02:43 PM
aerosam's Avatar
To answer all 3 questions:
1. No there's no spongeyness, brakes all bled nicely.
2. EBC Greenstuff pads all round
3. Don't know the dia of the ATE master cylinder - still trying to discover that. I' slightly embarassed to say I don't know what you mean by hydraulic ratio - could you explain please? Thanks!
Old 15th May 2011, 03:01 PM
aerosam's Avatar
Ok - after lots of digging through BMW websites, I've found the master cylinder is 25mm diameter.
Old 21st May 2011, 09:48 AM
allterrain's Avatar
allterrain allterrain is offline
Hi aerosam, there are a number of articles on the web regarding mcyl sizing and pedal ratios which should help, basicaly a smaller diameter mcyl will give you more brake pressure with slightly more pedal travel and you shold have a pedal ratio of about 6 to 1. Here are a couple of interesting articals; http://www.hotrodheaven.com/tech/brakes/ and http://www.markwilliams.com/braketech.aspx . Cheers Brendan
