Old 14th August 2011, 10:06 PM
Question Diff position.
I am well under way with my mock up build but am unsure of position of diff unit. What i need is a dimension that would represent the driveshaft centerline both in height from underside of the chassis and distance back from a reference point. Cant find anything in the book, i am not useing a sierra diff but want to keep book driveshaft angles ect. Anyone???????????????????
Old 14th August 2011, 11:07 PM
Tilly819 Tilly819 is offline
you can calculate the distance back from reverse engineering the drawings from the center line of the rear upright, threw the rear wishbones onto the chassis pickups as for the height i would not be determined to keep the book angles basically in the ideal world at neural ride height under no load the drive shafts want to be angled down slightly from the diff to the wheels this allows them to become straight under acceleration as the suspension squats.
a little more info may help, what diff and shafts are you planning on using?
tilly
www.heraldic-motorsport.co.uk
Old 14th August 2011, 11:27 PM
A picture of the top mounting bolt pattern ,http://t1.gstatic.com/images?q=tbn:A...W-lyOikxZ_ppSw
Another with discs and brakes all together
http://www.vxopel.com/pic/cobra/ra1.JPG
I wanted to use this unit with the inboard brake set up and retain all the sierra hubs ect. All i would have to do is make up some mongrel drive shafts.
Old 14th August 2011, 11:57 PM
There is no way that will fit in the book spec suspension cage, it is how ever very easy to mount. why not use sierra/granny rear disks and use 100mm bolt on cv joints with modded half shafts?
Old 15th August 2011, 12:21 AM
The diff unit would fit with no problems at all but dressed up with all the braking might be a different story. Worst case would be to just use the diff and retain the sierra outboard brakes. Those discs are 10" in diameter so its not as big in the flesh as picture would lead you to believe . I just like the idea of all those bits being inboard, makes hanbrake cable ,brake pipes all a lot easier, less unsprung weight less strain on all the wishbones under braking ,lsd and loads of different ratios. If it cant be it cant be but would like to have a go.
http://www.vxopel.com/pic/cobra/ra2.JPG
Old 15th August 2011, 12:44 AM
I'm not saying that the inboard set up can't be done it's just a case of why make it more complicated that it has to be?
