Old 21st August 2011, 04:04 PM
kitcarkid kitcarkid is offline
Question mini donor
ok so for my project i was planning to use a ford zetec engine but i had a thought
has anyone ever fitted a mini engine (bmw) in to a haynes roadster locost
i ask because i will soon be starting a new job at mini and if i can use a mini engine i might be able to get cheaper parts and will get servicing etc cheaper
anyone know if its bin done and would i need a differant gearbox?
if i can go ahead with it i plan to tune the engine
thanks
Old 21st August 2011, 06:26 PM
any1???? do u think its a good engine to use???
Old 21st August 2011, 06:46 PM
mark mark is offline
Probably not!
Never heard of that engine being used so inevitably it would be expensive getting an adaptor plate made for it to be mated to a rear wheel drive gearbox
Also figuring out the clutch set up to suit said adaptor and gearbox
A bmw gearbox wouldnt fit as the mini engines i believe are of crysler origins
Then you would also need to be fuel injected/cat etc etc to suit the emmisions standards for that engine
All perfectly possible but you wouldnt end up with a car any better that a zetec engined car, it would just cost you more and be more of a headache
Old 21st August 2011, 06:53 PM
Are you really being serious? You are considering using an engine that has no obvious rwd gearbox to mate just because u may be able to get cheap spares?
Old 21st August 2011, 06:54 PM
not just that i like minis anyway, want summet differant, and want a challenge
Old 21st August 2011, 07:22 PM
MarkB MarkB is offline
I would imagine that will create some proper headaches and not really worth the effort....besides real Minis don't wear a beemer badge
Old 21st August 2011, 07:36 PM
Ive driven a couple of "new" mini's, i would have said the stand out features were most definately the chassis and the interior styling. The engine particularly in the mini one was inert and lifeless, a bit more spicy in a cooper but nothing to write home about.
