Old 21st September 2011, 09:41 PM
rapidtornado's Avatar
Default weird welding?!?!
Guys
Looking for a bit of advice, I gave my beloved welder an early christmas pressie as I haven't used her for a while and treated her to new shroud, nozzle, wire and tank of CO2/Argon
Ran a few beads with power set at 4 (range 1-6) and speed at 3 (range 1-10) and got OK results, played with power and speed and got a decent penetration bead (see attached weld 1)
I then used the same set up and ran a bead on a join and got horrible holey welds (see attached, weld 2)?!?!? any ideas/suggestions as to what's gone wrong here?
Apologies for the poor quality pics off the BB
Rapid
http://i1142.photobucket.com/albums/...0Car/weld1.jpg
http://i1142.photobucket.com/albums/...0Car/weld2.jpg
Old 21st September 2011, 10:56 PM
My welds look like that when I forget to turn my welding gas on
Old 21st September 2011, 10:58 PM
Locky Locky is offline
looks like a weld over paint or some sort of contamination, is the steel thinner in the joins ie. ground down?
If it has breasts or wheels it will give you problems.
Planning Stage
Old 21st September 2011, 11:19 PM
Skov
welding gas was on for both pics no change made to regulator
Locky
yes the steel is thinner as it's ground at an angle
maybe I'll run a few more beads on a sample piece of steel and have a play with the wire feed settings
Old 21st September 2011, 11:24 PM
Didnt weld in a different part of your garage, where it is windier and its blowing away the gas?
Planning Stage
Old 22nd September 2011, 06:37 AM
yes I did actually... I shifted location so that could have been the issue, didn't think of that
cheers locky
Old 22nd September 2011, 02:32 PM
Question No shielding gas
Definately looks like a loss of shielding gas to me.
Would have needed to be quite draughty to have a total loss of shielding gas, perhaps you need to up the gas flow rate a little
Definately make sure that you protect the welding area from draughts tho.
Can't tell by the picture but if that is 3mm material being welded, personaly I would up the welding current up a little ( assuming you are using a 150 amp mig )
