Old 3rd October 2011, 10:30 PM
misty misty is offline
Default engine in
i have just sat the engine in and the gearbox bolted to it great BUT the engine a pinto 2lt(after the sump had been cut) is sitting approx 2" above the bonnet line in fact the carbs are sitting avery little more ,Has anyone any ideas is this ok or what has happened or how can i get over this problem.Hope you can help
Old 4th October 2011, 12:09 AM
Well done on getting to this stage, a great milestone of the build
I can,t help with regard using the Pinto ( I used the 1.8CVH engine ), did you make your own engine mounts? As they tend to dictate the height that the engine sits in the chassis.
There are a few members using the Pinto, but have a look at Ash G,s build photos as he used the Pinto originally ( lots of photos of his build in his signature ), might help in some way to clarify things .
Old 4th October 2011, 12:28 AM
as yet the mounts are not made but the engine is sitting level with the bottom of the gearbox and chassis but still it is above the bonnet, Had a look at the pics you mentioned but none that i could see where the pinto had been used maybe they have been removed, will have another look tomorrow oh mean today later
Old 4th October 2011, 12:32 AM
I presume you are using the Type9 gearbox? if so then the bottom of my bell housing sits 25mm BELOW the bottom rail of the chassis, I think a few ( probably most ) builds are like this , maybe if you lowered the engine/box by 25mm it would solve the height problem for the bonnet?
Sorry I don,t know for sure as I didn,t use the Pinto.
Old 4th October 2011, 12:36 AM
here,s a pic showing the bottom of my bellhousing in my chassis
Hope it helps.
Old 4th October 2011, 03:56 PM
many thanks HandyAndy engine in and level with floor still sticks out at the top but will make a bulge to sort that out many thanks again
