Old 12th October 2011, 07:39 PM
Default Steering column
I know most on here are using Sierra steering columns but has anyone used any others. The reason I ask is because I have had the offer of a triumph Spitfire column and am wondering if there is any reason stopping me from using this
Old 14th October 2011, 10:55 PM
phil clegg phil clegg is offline
Default column
its easier to use sierra but not everbody does,ive used pug 306 so all the controls are on n/s so you do not catch as you climb in ,horn also on same stalk,the problem with something different is there is not much help if you hit problems ,phil...
Old 15th October 2011, 08:32 AM
Thanks Phil, i think i will getit off him and see what i can do with it. The good thing is that the indicator arm is still with it and the ignition switch with two keys
Old 15th October 2011, 11:38 AM
make sure it is of a colapsable type for iva?
Old 15th October 2011, 08:36 PM
Thanks for the heads up on that Bazr will have a chat with him with regards to being collapsable
Old 16th October 2011, 07:41 PM
Never thought of that. I will have to check that the leccy corsa column I am using has got that
Old 17th October 2011, 08:20 PM
What a bummer steering column is one solid piece so no good, back to the drawing board
