Old 4th January 2012, 07:57 PM
tkpm tkpm is offline
Default Webbers or Bike Carbs
Hi all,
At the end of the month i should have enough money to buy everthing that i need to finish my car (finger cross).
The one thing i've been stuck on is the choice between webber carbs or bike carbs for my 2L pinto. Webbers would be easier for me to fit, but i would like to go bike carbs (like the way they look), but so many people have said i need these carbs or those carbs with a mega wossit and trigger thingy, i'm now totally lost...doh
Just bear in mind i'm not mechanically minded, if someone going to say bike carbs, PLEASE PLEASE give me a list of everything i will need, even then i my need help fitting it all lol.
Terry
Old 4th January 2012, 09:01 PM
I have treted myself to a nice pair of webber 45's, all i will say is its your build fit what you would like too see on your car, but webbers do look sexy as hell, good automotive bling
Old 4th January 2012, 09:05 PM
Speak to bog brothers . they should have a manifold to hand for bike carbs and be able to jet something like a set of ZX6r carbs nicely.
Regardless of Webber or Bike your going to need some form of ignition, whatever came with your engine should do as long as it was not an EFi... You may need to put a IAT in the air intake.
Personlay... My money is with the Bike carbs.
Old 4th January 2012, 09:33 PM
Isnt there a post on here somewhere with the article on bike carbs by Classic Ford Magazine?
Old 4th January 2012, 09:36 PM
righty ho ! ive had to make this decision myself as i bought a vauxhall with imobiliser issues !!! or created them.
basically im buying a set of throttle bodies from a local breaker for £50 plus the vat on friday but im going down to pick my carbs. to go with this i need megasquirt. now looking at all the sites attributed with megasquirt for my engine i have worked out i can run mine with existing sensors from my engine as the vauxhall sensors are "perfect" for megasquirt. for me this works out that i can get my engine RUNNING on megasquirt with the throttle bodies i settle on.
now if you can make a chassis you can make a manifold for throttle bodies im using the std injection rail from my engine and injectors but the spacing issue well its the ISSUE ! there are bike bodies that can be seperated and spaced to suit the inlet ports on your engine thus making or cutting your std manifold easy as the injectors are correctly spaced already.
this link is fantastic for a zetec guide basically the same for all http://www.sportingfords.com/forums/...hp?f=16&t=1960
and this is great for me
http://www.migweb.co.uk/forums/engin...ne-ms2-v3.html
but there are megasquirt forums you can just google.
for mine it looks that just over £550 all in i can megasquirt on bodies and buy a new acewell digi dash to display all the info i need
im sold on the bodies
Old 4th January 2012, 09:40 PM
ps if you do go bodies dont use ebay ! they all know the new use and have bumped up the prices pm me and ill hook you up with a tel number for bodies at the right price. but gsxr k1 k2 600 or 750 bodies work also triumph tt600 look like a good option easy to mod and r6 r1 carbs early versions can be split too
Old 4th January 2012, 09:52 PM
Bike carbs would be a bit more work than scouting round for a pair of webers that came from a pinto in the first place. I was reading a bit on bike carbs vs webers on a forum a while ago and there is not a power gain between the two but the webers were far easier to tune and performed much better on the road with a better mid range. That said bike carbs do look the dogs danglers.
