We haven't had a group buy for a while and I am in need of some new suspension bolts for my car as I've ended up using them for random jobs
. So I am happy to run a new bolt buy for the following:2 x M12 X 260mm Bolts - (Rear Uprights) 2 x M12 X 220mm Bolts - (Diff Mounts) <--- I have increased the length of these by 20mm from the previous group buys as the bolts I got were not long enough for my diff (standard sierra). 20 x M12 X 70mm Bolts - (Wishbones, Rear Camber Adjuster, Lower Shock Mounts) 6 x M12 X 60MM Bolts - (Upper Rear and Front Shock Mounts) 30 x M12 Nyloc Nuts - (Type P - these are a bit thicker than normal nuts and better suited to suspension applications) 30 x M12 Plain Full Nuts - (these are for test fitting components without ruining the Nyloc nuts) 60 x M12 Flat Washers - (Form A) 60 x M12 Black Plastic Nut Covers. All parts will be 8.8 grade, grade 8 for nuts and mild steel with BZP coating. From ringing out 3 different suppliers it seems that I can get all of the above for £27 with £8 postage on top for each set. If anyone would like a set then just let me know. 1. Tatey 2. 3. 4. 5.
1.8 Silvertop Zetec (ZX6R Carbs + Megajolt) + Type 9 My Build Blog: http://www.haynes.co.uk/forums/showthread.php?t=2736 - Last Update: 31st October 2020 Total Spent so far: Stopped counting
A suggestion Simon,two cap screws/allen bolts of the right length for the rear top shock mounts as it saves drilling large holes.
Can i add my name to the list please, if you let me have your address i will send payment as and when needed
Many thanks for this Arfon |
I have to say I've had no issues with installing nuts/bolts for the top rear shock mounts. Is this when trying to tighten them up? 1. Tatey 2. The Arf 3. 4. 5. Arfon, which address are you after? Paypal? Ideally I'd prefer bank transfer as it's free, so I don't get stung with fees. Is this ok with you?
Would just save a little hassle drilling such a large hole Simon.
Was thinking of sending you a cheque prior to purchase if that was ok, have only ever used paypal on the bay, am a bit of a techno phobic
Arfon |
Hi Tatey. Can you add my name to the list please. If you give me details when they arrive re bank account, sort code, etc. I will happily pay by bank transfer.
Bill |
1. Tatey
2. The Arf 3. yewtree 4. 5.
Hi Tatey, Please add me to your list, send bank details as and when. Pete
1. Tatey
2. The Arf 3. yewtree 4. tailwind 5.
