Old 10th March 2012, 07:59 PM
SeriesLandy's Avatar
Default Battery
I've got to the point where I need to position my battery so that I can put the cabling in. I've got a couple of sierra sized batteries that a slightly too large to sit in the saturn scuttle tray.
If I bought a new battery what would be best to go for?
Or leave it for the minute and just bodge the cables untill I'm nearly finished, then tidy them up?
Do a lot of people end up putting them in the passenger foot well (missus is only 5ft so wont remove her leg room)?
Also if anyone has some pics of the battery/ cabling to started I would be very greatful
Old 10th March 2012, 08:10 PM
I,ve fitted a standard Sierra sized battery onto the Saturn bulkhead/ scuttle......as you have found....the standard size battery doesn,t sit into the moulded shape on the bulkhead,
BUT
If you cut part of the forward INNER face of the moulding the battery does actually "Slot" into the recess, along with a securing strap this helps to totally hold the battery in position.
Once the battery is in position you can,t see the bit that was cut away on the inner face of the moulding
I,ll try & find a photo for you .
Forgot to mention.......You will probably find that you,ll end up endlessly tidying up the wiring thru the course of the build, I know I was always adjusting this n that until the build was totally finished so left the final "tidy up" of the wiring till the very end ( In the engine bay I mean )
Old 10th March 2012, 08:13 PM
I was thinking about doing that while I was writing the post. Would save me some money at the mo as I think I've got about 3 batterys kicking about. 1 must be good
Old 10th March 2012, 08:20 PM
This is the best photo of my battery position, please excuse the dangling wires ( everything was disconnected whilst doing the engine swap ), as you can just see.....the standard battery DOES fit into the moulded recess on the bulkhead scuttle .
hope this helps
Old 10th March 2012, 08:22 PM
Lovely, thank you Andy
I'll have a look at mine tomorrow night.
Old 10th March 2012, 08:28 PM
No probs, hope it helps,
another thing to point out........don,t under estimate how much of the split conduit stuff you,ll need, at times it feels like its never ending I think I bought about 25mtrs of the stuff in various sizes, tho it does tidy up the wiring quite nicely .
Old 10th March 2012, 08:31 PM
I know I ended up buying more and also Lots of cable braid as I think it looks nicer than split conduit.
