Old 19th March 2012, 08:54 PM
Exclamation Gel coat or Paint?
Hi all,
My friend Luke has ordered a fibre glass kit frm NTS Engineering but without a finished gel coat finish. I am now having second thoughts about having a gel coat finish as well. Luke wants a metallic finish but the thought of being able to fit your GRP kit without worrying about scratching or damaging them seems appealing.
I know from previous posts from Fabby that gel coats fade with time faster than paint.
Does the cost of a gel coat finish against the cost of spraying the parts once finished justify the price?
Basically what I'm asking is it better to gel or paint.
Any opinions on this matter would be greatfully appreciated....
Old 19th March 2012, 10:21 PM
MarkB MarkB is offline
Panels will or should be gel coated anyway. If it's for painting then they are usually done in grey or white gel. There is a painting specific gel which is easier to sand but costs a fortune.
If you want a metallic finish then specify the colour you want in gel and pre fit it to your car then once happy with it all flat it off and use metallic clear coat and you have metallic finish from a gel original.....But the original finish needs to be top notch as if just used as a polished finish.
Old 19th March 2012, 11:53 PM
I dont think there is a problem with fade. There are three westies running around here which are immaculate, one of them is a dark blue and its got to be 15 years old if its a day as its got an escort axle in the back. All of them still in the gelcoat and no fade. I have seen red bleach before but that was yonks ago and even that polished up ok. They might have escaped it because they are garaged!
Old 20th March 2012, 05:47 AM
Wynand's Avatar
Wynand Wynand is offline
Keeping it out of the sun did help in a big way and perhaps the fibreglass man got things right when making them....
I think it still has a gelcoat, albeit a clear one applied to have the smooth mold finish, read below.
I work with GRP basically on a daily basis and for years had built boats and other fibre stuff for a living and am on record many times for my mistrust in gelcoat.
I would venture and say as much as 90% of all gelcoats applied to molds are much to thick according to specs and herein lies its danger. Styrene get trapped in the molding because of that and over years (especially when exposed to sun like boats) would surface through the gelcoat hence the fading / discolouring and a common symptom is cracking of the gelcoat and usually starts as little hairline spider web like crack. In severe cases the gelcoat just open up in cracks.
The reason many apply the gelcoat thickly is to get coverage to prevent brush streaks especially with "difficult" colours like red for instance. The best way to apply gelcoat is to spray it on evenly and the equipment for that is very expensive and I would venture and say that no manufacturer doing seven body moldings have this type of equipment.
The reason why gelcoat has to be applied to the mold is to get a smooth surface - laminating directly against a mold result in many small pin holes because of resin not fully saturated through the CSM and is very difficult to repair because of its small size.
The way I did my car's body moldings was to use white gelcoat very sparsely (streaky see through) and just enough to get a smooth surface finish from the mold. These parts were later lightly dry sanded down with aluminum oxide sanding sheets (360#) and two pack epoxy primer and top coats paints applied.
All good two pack epoxy paints are far superior than gelcoats and will outlast it and you obtain a better finish with deep colours if you applied a few coats of colour top coat and optional clear coat applied if you want to go that way. And you can basically have any colour you wish for...
Wynand
http://5psi.net
Old 20th March 2012, 12:10 PM
shh120m's Avatar
shh120m shh120m is offline
The panels are being done in white, at a discounted price because im not rubbing out or polishing up imperfections which seems to take forever
Old 20th March 2012, 05:20 PM
My advice for what its worth would be to go for a colour and leave it for a year then paint. Grp moves around a lot initially and takes a while to settle down. I made that mistake on a cobra kit and ended up having to repaint it, the main problem areas seem to be around the engine bay so I assume its the heat related.
