Old 20th May 2012, 10:53 AM
Default Rear upper wishbone
Ok i have hit a dilemma.I have tacked on the wishbone brackets and trial fitted the rear wishbone assembly.One side is all good but the other i have a problem with the upper one as it does not fit in the correct position because the 257mm is actually only 249mm.These were bought from a supplier(Saturn) so not easily rectified.Do i just tack the brackets to suit the incorrect dimension or try to resolve the wishbone problem?(Dont really fancy making the jig for 1)
Also i seem to have lost 4 of the crush tubes! Does anyone supply these seperately or are Rally Design my best bet?(i know i would need to machine 2mm off these though).
Old 20th May 2012, 11:23 AM
Hi Oz.....two ways to do this use a vice but the opposite ie use it to expand the wishbone or the way I did it is to apply some heat just above the weld joint on the outside then cool it straight away with a spray so it contracts quickly you will find it will gradually move over on repeated attempts.....you could even combine the two, I think the brackets are more important re positioning, like I say mine distorted a little after being welded and I think most others peeps will have as well
forgot I put it in my build thread here
http://www.haynes.co.uk/forums/showt...?t=4493&page=6
Old 20th May 2012, 11:30 AM
Have wondered about heating it but being as its 8mm im wondering about the bushes still being inline
Old 20th May 2012, 11:57 AM
hi Ozzy
I expect the wishbone pulled when being welded, that said 8mm is quite a lot, perhaps it was taken from the jig too soon !
Have you checked to see if the bush tubes are still square & true with each other ?
Easy to check on a flat surface with a couple of pieces of angle iron set at 90 degrees
You'll soon see if things are out of line.
If out of square then stretch them out as Kev has said.
I still have plenty of materials here & would be more than happy to make you a free one.
Downside is, I guess it'll not be very cheap to have it shipped over to Aus
Just let me know if I can help you out, would be happy to do so.
Old 20th May 2012, 12:22 PM
Assuming that the wishbones were fabricated in a propper jig, when welded up, the wishobone tubes would have been set at the correct alignment.
If they have pulled badly during cooling down( They will pull a lot more if you tack them in the jig & remove them for full welding )
The bush tubes will then be badly out of alignment.
If that is the case then being stretched out should bring them back into line
Edit
This post would make a lot more sense if Talonmotorsport had not deleted his post in this thread !
Old 20th May 2012, 12:35 PM
Ok i have put it on a flat plate and both sides have pulled in as i have a gap of 0.7mm under the bush at the front inner edge so hopefully heating it and encouraging it will solve the issue.The only annoying part is that its already powdercoated
Old 20th May 2012, 12:04 PM
put a piece of pipe through if you are unsure but it is highly unlikely as you would have to impart a twist for that to happen and you wont be just make sure any "pressures" are square on
