Old 31st May 2012, 10:46 AM
FASTdan FASTdan is offline
Default danST Engineering
Hi All,
Some of you may know us from the locost builders forum among others. Just a quick post to make everyone aware of what we can offer:
Bike carb and throttle body manifolds. Fully TIG Welded aluminium construction built to suit whatever carbs/bodies you source. We also build these into complete packages consisting of carbs, manifold and fluoro lined fuel resistant silicone hoses (in a choice of colours).
Self weld Mild Steel Manifold kits. Again to suit whatever carbs you source. These kits consist of 8 tube sections cut and marked ready to weld to give your required engine/carb spacings and the 8mm flange plate to suit.
Pipercross PX500 and 600 Filter baseplates. Either blank or cut to suit a variety of bike carb applications. We also stock the filters.
Velocity stack kits to suit the popular bike throttle bodies.
A wide range of laser and water jet steel, aluminium and stainless steel manifold plates to suit most popular ford engines aswell as other manufacturers.
We also stock the popular DCOE/Jenvey type plates in 10mm aluminium.
Duratec Engine Mount kits designed to suit the MK Indy/Book Chassis.
Prop Shaft Catch Plates. Designed to mount in the tunnel of your Locost to capture the prop in the event of a failure.
The above is not exhaustive, other products and information can be seen on via the following links:
www.danstengineering.co.uk
http://stores.ebay.co.uk/DANST-Engineering
http://www.facebook.com/pages/Danst-...8944900?ref=ts
Any questions please email enquiries@danstengineering.co.uk.
*Edited to remove pics as they were far too big, please see above links.*
Thanks for looking.
Regards
Dan
danST Engineering
Old 31st May 2012, 03:55 PM
Tatey's Avatar
Tatey Tatey is offline
I ordered an aluminium inlet manifold for my ZX6R carbs for my 1.8 silvertop zetec from Dan and it fits perfectly and looks the business. Just need to press on with the rest of the car to get the engine started!
I'd definitely recommend Dan in the future and I'm sure a lot of other people would over on locost builders.
Old 31st May 2012, 06:08 PM
carlknight1982's Avatar
Spoke to Dan on the phone on a couple of occasions, Very helpful guy and good sound advice, knows his trade well.
Roadster No 2 build
Cost to Date : £93
