Old 7th June 2012, 08:08 AM
ashbudd7 ashbudd7 is offline
Default Engine mount box section query
Morning everyone,
With regards to the box section for the engine mounts (I'm using the dohc) would I be ok using 45mm with a 2mm wall box or should I order up some 30mm? If I do need 30 which wall thickness should I get, 2 or 3?
It's just that a) I've found some 45mm and b)is the 30mm strong enough?
Thanks
Ashley
Old 7th June 2012, 08:18 AM
you would have to show us your planned design to get any idea.
Old 7th June 2012, 08:39 AM
brainbug007's Avatar
If you're making the custom engine mounts described in the book for non-pinto engines, personally i'd go for the bigger stuff as by the time you drill the hole for the bolt and then put the lock nut on, it doesn't leave that much space to get a spanner/socket in there to tighten it up. I'd also go for 3mm personally as I would think 2mm could end up bending under the weight & twist of the engine?
Old 7th June 2012, 08:43 AM
Ah, well I'm at work at the mo so can't provide pictures but here goes:
I've made two plates to the same profile and hole pitches as the original mounts to bolt to the engine and two plates to bolt on to the land rover rubbers that are on the way. The rubbers will be mounted to 3mm plate welded to the bottom chassis rails as per book. Then I'll bridge the gap with the box section I've mentioned. At the moment I've worked out all the angles and lengths but this is based on 40mm box. The drivers side will leave the engine at a 48.07 degree angle and is 224.77 long along it's longest length.
Hopefully this makes sense and helps!
I'm open to any criticism/suggestions
Ash
Old 7th June 2012, 12:26 PM
I used 30x30x2 box section, I don't expect it to cause any problems.
Old 8th June 2012, 08:13 AM
Brilliant, thanks for the replies. I've ordered up some 40sq 3mm wall to be safe.
Ash
Old 30th December 2012, 04:03 PM
jps jps is offline
Just about to fabricate some mounts for my Pinto, i thought the book spec was 6mm plate across the chassis rails and at the ends of the box section, but have other people used 3mm with success?
