Old 7th July 2012, 03:41 PM
tkpm tkpm is offline
Default Whats this for
Hi guys,
As i've lost all my saved photo's from when i was dismantling my doner, i can't remember what the bit below is for.
Thanks Terry
Old 7th July 2012, 06:03 PM
rpjg1975 rpjg1975 is offline
My donor was a 1.8cvh sierra and from memory I have a similar relay, fairly sure it is one of the main relays? Sure tt or someone will be along shortly to confirm.
Russ
Old 7th July 2012, 06:12 PM
Looks like the engine management master power relay.
Old 7th July 2012, 10:30 PM
From memory the only relay with a fuse attached to it like that is the radiator fan
Old 8th July 2012, 09:07 AM
brainbug007's Avatar
I had one like that except it was green (with its own fuse). It was part of the ECU from memory so I removed it because of using a megajolt.
Old 8th July 2012, 10:35 AM
I can't remember what donor car you had Terry
That relay has the same part number as the Sierra I am currently working on.
It's DOHC fitted with the exact same unit & it is the fuel pump relay.
The colour codes of the wiring don't match mine though.
I guess if you do not have an EFI engine it won't be the fuel pump relay.
