Old 22nd August 2012, 10:33 PM
tkpm tkpm is offline
Default Dim/Dip Relay
Hi Guys,
This going to be a two part question.
Is it best to stick with headlight set up use the dim/dip relay or can i do away with them.
If i have to keep using them, whats the relay code as seem to have misplaced them or i've mixed them up with some spare relays i have collected over the years,
Thanks inadvance
Terry
Old 23rd August 2012, 04:07 AM
Why would you want to do away with it,surely you need to be able to dip your lights.
Old 23rd August 2012, 06:51 AM
All the dim/dip relay does is, when the side lights are turned on, it puts 6v into the dip part of your main headlights.
The idea was to make the car more visible, most modern cars don't use this system anymore.
Terry
Old 23rd August 2012, 01:15 PM
Be modern Terry dont bother,more hassle.
Old 23rd August 2012, 05:56 PM
Thats what i was think flyerncle.
Thanks all
Terry
Old 23rd August 2012, 06:42 PM
If you want visible Terry,use a strip of white led's behind the grill when its finished.
