Old 20th September 2012, 09:24 PM
DaveyB DaveyB is offline
Default Weld finishing
Hi I wonder what is the best way to finish off my welds i know that some people may have finished them back to flat, and Where body panels are fitting I am sure this would work, but where they don't I was just going to leave them quite proud seems like grinding right back would be undermining them.what are people's thoughts sorry if this has been addressed previously
Thanks
DaveyB
Old 20th September 2012, 11:58 PM
I would only grind them back where you need to for panels etc. Any others I would just give a light clean over if you have any large lumps or bumps in them.
Old 21st September 2012, 09:32 PM
I find a flap wheel works well for dressing down welds. I use the flat type of flap wheel in an angle grinder, does the job and doesn't keep trying to throw the grinder skywards.
Old 22nd September 2012, 08:09 AM
Thanks for your help I was considering buying a power file what do you think?
DaveyB
Old 22nd September 2012, 08:13 AM
Just use a flap wheel in your grinder they are very good for this type of thing.
I use this type because they are free
http://www.ebay.co.uk/itm/10x-115mm-...item3f14bcf7c3
Old 22nd September 2012, 09:39 PM
Thanks for the reply and link know knew what I am looking for, I think my main concern is the noise of the grinder and upsetting the neighbours I,ll just have to do it in sort bursts.
Thanks again
DaveyB
