I have just finished a brake upgrade on my 2 litre turbo 7. I was running 260mm solid rotors with Wilwood 2 pot Dynapro single calipers, but they were struggling to get rid of the heat.
The upgrade is 298mm Subaru WRX front ventilated rotors, Wilwood Dynalite 4 pot calipers, 1.75" pistons, with a 7/8" master cylinder. The offset of the WRX rotor is good for the sierra upright, and it fits ( just) into a 15" rim ( offset 38). The centre bore of the wrx is 55mm, so both the centre ( 63.5mm) and the middle of the rotor (132mm) require some simple machining to clear the sierra hub. The hub also needs to be redrilled for the Ford pattern. ![]() No more brake problems.... |
![]() bob
