Good evening gentlemen. I have a bit of a problem. I have not chosen a drive train yet, and I am at the point of building the "rear suspension framework". I know I can't(shouldn't) install SB4,5,6 and CP10, but is it O K to build the rest of the RS? I am sure I will be going with an IRS, but I'm not sure which one. Thank you, Don
Miss you Doug and Charlie!! |
If you want to go the sierra route don just ask, I am sure between the forum members we can find the stuff and get it to you.
Thank you, Bob. I hadn't thought of that. I will have to just get out there, and do some measuring. I will check a few more re-cycle yards in the area. I guess I should also start a "build blog", and post some pictures.....Thanks again Bob. Don
