Old 30th March 2015, 08:56 PM
Rosco Rosco is offline
A bit of an update tonight, I was looking on speedhunters today like I do most days, and they decided to do a little wright up with some pictures I sent in
http://www.speedhunters.com/2015/03/...owered-builds/
It's about half way down
Next on the list, the lathes all finished
Also I'm back on my pedal box, should get it all tacked up this week
Clamping the sides up square
Old 30th March 2015, 08:57 PM
Pedals
Flange bearings for the pivots
All the tubes will be tig welded in
And that's it for now
Old 30th March 2015, 09:00 PM
dubzter's Avatar
dubzter dubzter is offline
that pedal box looks amazing, keep up the good work
Old 30th March 2015, 09:30 PM
Tatey's Avatar
Tatey Tatey is offline
Lathe and pedal box are looking good Ross!
One quick question, it's probably the angle of the photo, but will you be able to fit a cap head to the bottom master cylinder mounting holes as the brackets look a little close?
Old 30th March 2015, 09:32 PM
Now that is a fine bit of fabrication if I do say
Old 1st April 2015, 10:21 PM
Cheers for the comments, it's going well at the min!
Yeah there's just room for a bolt
A bit more done tonight, I made some exhaust hangers at the weekend and my rubber mounts came today so got it all mounted and tacked up
Pretty happy with how it's worked out, sits where I want it to which in good
Old 2nd April 2015, 10:31 AM
Porn in metal that pedal set,shame it wont be seen.
Old 6th April 2015, 05:13 PM
Had a good few days on the car this weekend, got a bit done
Pedal box tacked up and in the car, there's still a bit to do on it but at least I no where my seats going
Front seat rails done, I've raised the front of the seat to lower the harness holes at the rear
Old 6th April 2015, 05:14 PM
Nuts welded underneath
Harness mounting bosses made
