#581
Made some people smile, me included.
Cheers Stot
1.6 Mazda B6 : Garrett TBO339 : 420cc WRX Injectors : FMIC : Microsquirt V3 : LC-2 Wideband : Toyota COP : 1.8 ATB LSD Build Started Jan 2013 : OTR Aug 2014 : Still OTR June 2024 |
#582
I have been trying to get a grip on my fuel usage over the last couple of weeks as I fixed my fuel guage recently.
Running 8psi of boost on a 1.6 engine I'm getting 150miles a tank, or 25.5mpg. Same as my DD so I'm happy enough with that! Cheers Stot
#583
Can't complain at that.....not like the roadster is a super slippery shape!
#584
Thanks |
#585
The guy that welded mine up hated it and said never again. Cheers Stot
#586
Added some bonnet vents. With the turbo my normal running temps are 103-110c even with a full mx5 reroute out the back so hopefully these will help a bit.
![]() Cheers Stot
#587
So THATS what that rattle was....
![]() Glad it only took 45 mins to change. If you get a china manifold, get a good quality pressed stainless gasket for it. The China one was aluminum is seems. Cheers Stot
#588
I'll have to buy a fitting then, I wish I had a lathe.
190E? "The Mercedes 190E radiator that many of the Haynes Roadster guys use has an oil cooler built in. eBay Item Its upside down in those ebay pictures, the red caps are on the oil filter in/out. Cheers Stot" Last edited by CTWV50 : 13th May 2015 at 08:47 PM. |
#589
Have you thought about waterless coolant or maybe removing the thermostat? These are things I'm considering.
#590
My temps still run at upto 110c. I have a full reroute in place and the fan switch is at the thermostat. In traffic the fan will come on and bring it back down to 102. It seems my fan switch actually comes on at 110 and off at 102 rather than 97/92 as its supposed to. Its new too. Im going to try running the fan off the ECU for a while at a lower temp to see if that helps but It will probably just end up with the fan on permanently. If not ill try without the thermostat to see if it overcools then but really its when im going 70-80mph on the motorway im getting the most heat into the engine, its sitting at 4000 rpm so whenever you apply some throttle its into boost. I think the radiator just isnt removing enough heat so I have a spare 190 radiator with a hole in it and Im thinking of sending that off to have an aluminium twin or tripple core copy made up if nothing else helps. Cheers Stot
