Old 19th May 2015, 02:47 PM
So this morning I had a look at the coil packs and they seemed fine no bad connections or anything, removed the fuel pressure gauge and then fired it up, then I turn it off and put the spark leads in the correct order! Measured the voltage at the battery 14.4v turned on the lights 13.5v, rear fog and main beam and I was dipping into 12v territory. Thanks for the tips everyone my finger was hovering over the "buy it now" button for some coil packs last night, I did check the earths, but I was paranoid about good earths when wiring up the engine and the earths were solid.
Going to take the 1.8 alternator off the 1.8, change the pulley on the alt or the 1.6 engine pulleys and see how I get on. No money spent and a easyish solution.
Old 19th May 2015, 08:51 PM
Stripped down the front of the engine, nose off, etc. No sheared bolts fortunately, but the crank ribbed pulley is chemically welded to the toothed crank pulley behind. I've t*****d it lots but have given up for the evening and left it soaking in WD40. If it still stubborn in the morning I'll be using fire. Oh and I've caused a leak from the water pump inlet so I'll have to fix that too!
Old 20th May 2015, 09:57 PM
All fixed, managed to get the crank pulley off this morning and fit the 1.8 pulleys, this evening I got the 1.8 alternator in and everything back in the engine bay including fixing that coolant leak from the rotted 6mm pipe I disturbed, it was going to go eventually anyway.
I now have a steady 14.4v with the lights on or off which is much better than before. 1.8 alt is bigger and needs a larger ring connector which fortunately I had. ribbed belt is a better design too so it solves the v-belt 1.6 issue aswell.
Nose on in the morning and then fit the 300lb springs and take it for a drive I guess!
Old 21st May 2015, 08:30 AM
Better to have found the perished hose at home rather than on the side of the road
Old 21st May 2015, 09:02 AM
Ianr Ianr is offline
All fixed,
I'll be interested in your feelings about the 300lb springs, I've eaten a few more pies than you and have 250lb fitted
Ian
Old 21st May 2015, 10:27 AM
Ian
Yes let us know what the ride is like, it's not so much a weight issue with me it's the way the back end rolled on a recent track day.
Old 21st May 2015, 06:58 PM
Got it all back together, engine issue is resolved Rev cleanly all the way 7k every time now. Springs have reduced sag yet maintained grip in the corners. Walking as I type so excuse any errors. I did manage to clip my number plate though and rattle a wheel arch loose! The list continues !
Old 22nd May 2015, 02:42 PM
BLOODY CATS EYES! lol
Went too fast between two single lane speed bumps, cleared the speed bumps fine but when the suspension squatted down at the front I must of caught the reg on a cats eye or something! Haha how ironic! lol
Just to expand on this I can go quicker on bumpy surfaces especially big dips in the road and small hump back bridges. I haven't lost the balance when cornering etc. Understeer is gone and oversteer is available through aggressive steering input! I like it! Geometry needs sorting though I just can't get it right. Going to have it professionally done soon.
Other things of note, I've changed my wing mirrors for lifeline single seater race mirrors, I still haven't made a rear cover. I still haven't strengthened the pass side wheel arch support, I have reinstated the the indicator stalk as the buttons are not convenient for fast road driving. I have fitted a weld-on steering boss from rally design to a 2nd column I had and removed it immediately to be sent back to rally design, too much play in the splines, probably the last thing I ever buy from them there unbranded products are utter s***e. I'm not bothering with a removable steering wheel I've bought a gear/handbrake lock instead. I haven't done the stripes yet either!
Old 22nd May 2015, 02:54 PM
1.8 alt and pulleys on a 1.6 engine!
Old 24th May 2015, 10:51 AM
norton norton is offline
Hi,
I've read through your thread (great read and very useful) but, an I probably missed it but what brand bodywork did you use?
Gav
