Old 8th June 2015, 09:48 PM
SteveH1 SteveH1 is offline
Hi All
My book came today
Just had a quick flick through but doesnt seen to be much about the chassis table
Like how many legs did people put on there bench.
And what height did people build their bench at.
Thanks
Stephen
Old 8th June 2015, 11:33 PM
vmax1974's Avatar
vmax1974 vmax1974 is offline
Hi I built my table about 900mm high and 4 legs make the top from the thickest sheet of ply you can get and still brace the underside to eliminate the chance of it sagging time spent bracing and getting it right will save massive headaches later
good luck
Old 9th June 2015, 07:44 AM
Rosco Rosco is offline
Good luck mate!
My Build Thread
Old 9th June 2015, 10:34 AM
Pick your wood carefully as getting a straight piece will save you time planing and truing. 1" thick MDF as a table top is my recommendation but don't get it wet. Also use lots of wood glue.
Old 9th June 2015, 08:35 PM
Badger Badger is offline
I'd be tempted to keep your eyes open for a steel tubular table or something similar and clamp the wood on top - alternatively make the top of the table only and mount it on steel trestles.
The reason for this is that once the chassis is made and tacked strongly together it is very useful to be able to get at it from all angles at a reasonable height.
Here's my build table (and the project before my Roadster):
Old 11th June 2015, 07:30 AM
RichardH RichardH is offline
i went to a local salvage place dealing in office furniture, i bought three school tables like you would find at primary school, about 4'x2' , they have 25mm box section legs then i bolted 4x2 timber along both sides then sheeted with ply over the top. now i am further on i took out the middle table for working on the engine area and the front and rear is still supported on the other two tables
Old 20th September 2015, 08:56 PM
So i got my table built a few weeks ago and decided to put adjustable legs on it as the floor in my shed is rubbish
Old 20th September 2015, 09:06 PM
I got my welder during the week its a Swp redline 210
I got it as a package including gas and wire for 750 euro.
i assembled it and it seemed a bit cheap like typical chinese stuff but to my surprise it welded really well
First welds by stephen harborne, on Flickr
The first welds
Welder by stephen harborne, on Flickr
The welder
Old 20th September 2015, 09:15 PM
So i havnt got my steel yet i will be ordering it tomorrow
But i had some 3 inch angle iron so i started to make a bench for my vice
Vice and bench by stephen harborne, on Flickr
Then i stripped down the vice as its old and looked a bit worse for wear
i then took a wire brush to it
before
After
Just needs to be painters up now
Old 20th September 2015, 10:01 PM
Way to go Steve ....as good as any of our kick off's.
