Old 21st March 2015, 05:36 PM
vmax1974's Avatar
vmax1974 vmax1974 is offline
sunday afternoon i started looking at what i had collected and making jobs lists and set to work on the first job which was a seized wheel bearing on the front right side so removed the hub and sorted a new bearing and thats about where it is now i have removed the exhaust manifold as it was touching the starter cables so looking out for a standard zetec manifold to use till funds allow to have a stainless one made
i have also removed the inlet manifold to have that cleaned up blasted and painted/ powder coated
going to have the front hubs done at the same time once funds allow
[IMG][/IMG]
[IMG][/IMG]
Old 21st March 2015, 05:42 PM
vmax1974's Avatar
so what still needs doing well.....
i need to source a megasquirt II ecu kit
some instruments
some ford wheels
clean out the gearbox
find the correct ends to get fuel into the fuel rail [IMG][/IMG][IMG][/IMG
work out where to put the fuel pressure regulator
[IMG][/IMG]
finish the seat back and trans tunnel bolt together and iva.. well maybe not quite that simple but its a dam good head start
Old 24th March 2015, 04:55 AM
jasongray5's Avatar
I thought the red blocky thingys in the end of the fuel rail said sizes on them? I will search my email from the bloke who made the rail and see if I cant shed some light on the subject!
Jason
Old 12th April 2015, 07:58 AM
vmax1974's Avatar
Ok just a update have not had as much tine on the car as I would have liked due to putting one of the wifes workmates cars through its test and then having a few days down in the south anyway....
I havr been looking out for some front brakes and a set came up on locostbuilders he was asking 50 quid but me beimg a tight northerner got them for 20 quid result I thought for discs pads and calipers oh and a set of flexies which i may sell on if they don't fit my car
Still on rebuilding the hub with siezed bearing just need to put the new wheel stud in and get the bearing carrier pressing into the hub
Brakes pics soon
Old 16th July 2015, 08:15 PM
vmax1974's Avatar
Been Making a little progress lately found some front calipers and disks on locostbuilders they were only £20 so snapped them up and got them home [IMG][/IMG]
and painted them up and installed a seal kit
[IMG][/IMG]
[IMG][/IMG]
Old 16th July 2015, 08:23 PM
vmax1974's Avatar
[IMG][/IMG]
then i started on the hubs remover them ripped them apart then thought maybe i should take a photo
[IMG][/IMG]
looked at the studs and they were petty badly chewed so went onto the bay and got these
[IMG][/IMG]
Old 16th July 2015, 08:34 PM
vmax1974's Avatar
then thought maybe some new studs should be added so got a full set and the new bearings
[IMG][/IMG]
so the last few days i have been cleaning up and painted one of the hubs
[IMG][/IMG]
then installed the new studs
[IMG][/IMG]
so all i have to do is press the new bearing races and seals into the hub put them back together then move on to the next part of the build
Old 16th July 2015, 08:39 PM
vmax1974's Avatar
i know its not much progress but am not able to spend much time in the garage at the moment due to work commitments but even small progress is a forward movement
Old 16th July 2015, 08:48 PM
Nice to see your making some progress. I miss the parcels arriving at the house with car bits all the time!
Old 16th July 2015, 08:58 PM
vmax1974's Avatar
I know what you mean the wife keeps saying" what you been ordering now"
If she only saw what goes to my mums then sneaked into the man cave lol
