Old 19th July 2015, 10:54 PM
vmax1974's Avatar
vmax1974 vmax1974 is offline
I made a support in aluminium to put the reservoir on the bulkhead, and connected the reservoir to the M/C with low pressure brake fluid hose, clamps on the reservoir connections, and male/male hose connectors on the M/C ends.
Pictures will speak better than me
https://www.flickr.com/photos/994983...57643576951405
If you use a Sierra reservoir, I can send you the drawing of the support so you can print your own stencil if you want.
Cheers.
I could use those drawings myself
Old 20th July 2015, 07:46 AM
Originally Posted by NeilW View Post
Great info, quick question about separating the resevoir. Does it just simply 'pull' off the m/c?
Yes. It could seem hard, but that's the way.
And when you connect the male/male adaptor do they just push fit into the m/c?
Thanks
Yes. The only problem is the inlets in the M/C have a 12mm (or 1/2'') diameter, and the larger low pressure brake fluid hose I found has a 10mm diameter. You will need 12-10 reducer connector like this one in acetal, or this one in brass.
Personally, I ended up using the acetal ones, the first barb is bigger than on the brass ones, and it looks more secure.
2014-07-23_13-31-45 by Sylvain ROIG, sur Flickr
Hope this help
Old 20th July 2015, 08:32 AM
No problem
Please send me your personal email address in a PM, and I'll send you the PDF drawings to print.
Thanks!
Old 20th July 2015, 08:42 AM
Fiat and Ford have remote cylinders,may be of some use.
Old 14th August 2015, 06:48 PM
silvertail silvertail is offline
Question
Hiya, just wanted to check (and sorry if this is hijacking the thread) - does the 10mm hose fit OK on the 12mm reservoir outlets, or did you get a special reservoir with 10mm outlets as well?
Old 14th August 2015, 09:33 PM
Hi,
I could force-fit the 10mm hose on the 12mm outlets of the Sierra brake fluid reservoir. secured with clamps.
2013-10-26_18-03-03 by Sylvain ROIG, sur Flickr
2013-10-26_18-03-13 by Sylvain ROIG, sur Flickr
Old 18th November 2016, 03:57 PM
jps jps is offline
Sylvain, this solution using the Sierra MC looks excellent! Do you mind pm-ing the drawing for the mount to me too?
Old 18th November 2016, 10:45 PM
Never spotted this thread, but it's very useful.
Regarding the rear line. It should be split at the rear as has been show, there is no advantage at all putting the T up front, it increases the complexity, cost, chance of failure, fluid quantity required, impedes bleading, etc...
Old 24th November 2016, 09:10 PM
Hi,
Did you get my pm last week? If not please let me know and I'll send it again. Or you can send me your personal email address by pm if you prefer.
Thanks!
Old 25th November 2016, 01:19 PM
jps jps is offline
Hi,
Thanks!
Sorry - had a busy week - yes, have PM-d - much appreciated
