Old 20th September 2015, 05:54 PM
Rosco Rosco is offline
More done today, loads of bits and bobs to do, got my clutch cable sorted, had to make a bit at the pedal end and solder a bit on the other end, it wouldn't solder to start with, to hot I think, but got it done in the end.
Also got all my aluminium engine cradle spacers back on and tightened up.
Then went down my dads and made my air filter backplate ready for the itg filter, I got a drawing from ITG for the outside
Came out mint
Pretty much there now, just need a few holes in it for wiring, air temp and the fuel feed, also need some 3mm spacers under the trumpets to replicate what was there before as it's got orings that seal everything
My Build Thread
Old 26th September 2015, 07:10 PM
Steering rack and track rods re fitted
When I re fitted the steering shaft my break pipe was in the way so I had to make a new one
Rear discs and pads fitted
Done a bit more on my inlet, fuel rail all fitted and fuel piped up
My Build Thread
Old 26th September 2015, 07:12 PM
I removed the pins from the injector plugs ready to pass through a grommet but then decided I'm going to cut the lot and put a connector inline so it's easily removed
Also my air filter came last week and fits sweet!
My Build Thread
Old 27th September 2015, 08:42 PM
Had a morning on my dads cnc today
These are to go under my trumpets on the inlet to replicate the thickness that was there before
Handbrake cable tags
My Build Thread
Old 27th September 2015, 08:43 PM
Works like a dream to!
This is a bracket for over the diff, just need some more grommets
My Build Thread
Old 28th September 2015, 03:38 PM
norton norton is offline
Is that a home brew cnc machine?
Old 28th September 2015, 07:45 PM
Yes mate, it's wicked, he's built it all himself, it works a treat, considering I use real cnc mills all day at work, I prefer using his
My Build Thread
Old 1st October 2015, 09:19 PM
Well got a few jobs done this week, got my handbrake bracket fitted, really pleased with this as its held the cables dead in the right place
Decided on what switches I'm going to use for my dash, and got some switch guards, only thing there 4mm not 5mm so I think they will fail iva so I'm going to have to push some rubber tube over them I think
Also made a mount for my wheel speed sensor, there was a spare hole on the engine so I used this, it's going to pick up off a long bolt on the prop adapter
It sits closer than it looks, it's just the angle of the pic
My Build Thread
Old 9th October 2015, 09:24 PM
Right update time, been bitting and bobbing all week really
Rear lights temporarly mounted and wired to the front
Makeshift dash sorted so I can start to get things wiried
Battery cables done
My Build Thread
Old 9th October 2015, 09:26 PM
I'm using these terminal bars for my wiring
Toggle switches for my dash
My Build Thread
