Old 30th October 2015, 12:22 PM
Rosco Rosco is offline
how about get a flexi one made up with your brake lines?
edit: sorry you had already said that
i think a copper one would be fine and also its not going to kill you if it ever did fail
My Build Thread
Old 30th October 2015, 02:31 PM
The original is a coiled pipe, probably aluminium and then also a flexi you can see at the top of the pic.
Mine passed with that installed.
Now I only have a HEL Flexi line in a coil connecting the two.
Old 30th October 2015, 03:04 PM
norton norton is offline
I've been thinking of how to use the or setup but it seems long winded given the position of both cylinders. It still possible though.
Old 30th October 2015, 03:08 PM
Have you a pic of the flexi you've used at all?
Old 30th October 2015, 03:28 PM
Stainless braided hose with two different fittings on the ends.
Old 30th October 2015, 03:59 PM
Kerr-ching.
Old 31st October 2015, 12:23 PM
I hate brake pipes
Old 31st October 2015, 02:27 PM
Not at the moment but heres what I ordered from HEL, £30.
Create Your Custom Brake Hose
Code: CUSTOM
Options: Fitting 1: Swivel Male 3/8" x 24 UNF , Fitting 1 Angle: Straight , Fitting 2: Swivel Male M10 x 1.00 , Fitting 2 Angle: 20° , Support 1: None , Support 2: None , Colour: Transparent , Ferrules: Black Heatshrink , Length: 600mm
I did a loop in it and losely zip tied itso the loop could expand and contract with the engine. In hindsight I would probably put a 20* angle on both ends for ease of fitment.
Old 31st October 2015, 06:32 PM
I've had a tinker mocking up a copper line but it didn't feel like a proper job. I think a flexi hose is on the cards. Thanks for the info stot. It gives me a good datum to use.
Old 1st November 2015, 01:01 PM
Does anyone have a link to someone who sells the diy hose fittings but doesn't a flat £10 postage?
