Old 17th November 2015, 09:02 AM
Put the tube partially into the central hole you make in the middle and weld both sides,much stronger.
Put at least 10 mm bolts through roll bar mounts and not book nuts and bolts,domed plated 12.9 cap screws look much better.
Just a suggestion and personally I am happier with it.
Westfield use one bolt through the base of the tube !!!!
Old 17th November 2015, 11:58 AM
SteveH1 SteveH1 is offline
Ah i get you now thanks
Old 2nd December 2015, 08:57 PM
Ok so got a bit more of the rear all tacked up
Also got the cabling i need to supply the welder properly
Old 3rd December 2015, 08:11 AM
Rosco Rosco is offline
getting there now pal
My Build Thread
Old 3rd December 2015, 08:21 AM
Yea its slow going but im in no rush.
I was all set it get a good few hours done last weekend then i woke up on friday night and felt like i had poked myself in the eye.
Long story short i got steel in my eye during the week in work and never noticed
And it took the doc half an hour with a needle to scrape the rust out not a pleasent experience.
Old 5th December 2015, 11:05 PM
I got a few hours this afternoon in the shed.
So i started on the rear panel rails and it was something i wasn't particularly looking forward to as i didnt know anyone with the capability of bending the tubes so i had to notch the tubes to get them to bend
I was also worried about trying to get the two of them to match
So i welded the two tubes together temporarily cut the notches and bent the tubes together
This worked quiet well it also ensured that the two bends were perpendicular
Not the nicest to look at
Old 5th December 2015, 11:06 PM
Old 6th December 2015, 07:44 PM
If you know a plumber you can bend 22x1.5mm ERW tube in a Rothenburger tube bender quite nicely.
Old 6th December 2015, 09:42 PM
SeriesLandy's Avatar
I used my dads electrical conduit bender for my rear tubes.
Then I cut them off and put them in the bin as I ended up with a grp rear tub. (Vmax)
Old 6th December 2015, 10:19 PM
Dont know any plumbers.
Ordered a cheap bender on amazon so ill give that a try.
Does the the grp rear not fit with the bars in place.
