Old 4th January 2016, 01:32 PM
rpjg1975 rpjg1975 is offline
I managed to get an rs boss for 99p a while back that fitted my aftermarket wheel but they cost silly money now so there might be a market for them....
Old 4th January 2016, 01:42 PM
MrFozzieBear MrFozzieBear is offline
I used two aero Aero Catches in the same position as Rosco but also used these at the front:
http://www.kitspares.co.uk/index.php...70&search=Pins
Not the cheapest but works well and looks clean.
Old 23rd January 2016, 08:11 PM
Rosco Rosco is offline
Bit of an update, I've been flat out with every bit of spare time trying to get this thing somewhere near finished
I drew this up and made one, it's so I can use the bike fuel filler cap so the keys the same for the ignition and the tank
It was quite tricky to draw it up but turned out great
Started on an oil catch tank from an alu water bottle
My Build Thread
Old 23rd January 2016, 08:13 PM
Got some logos made up for my centre caps
Couple of bonnet location pins made
Got some front arches from MK, there proper smart, well happy with the quality of them
Decided to get some tube bent as the flat bar looked a bit naff
My Build Thread
Old 23rd January 2016, 08:15 PM
I used m5 rubber well nuts in the tubes to bolt them on, took me all day and stressed me out trying to get them right! Turned out ok in the end
I've not mounted them to close to the tyre as I want to be able to swap wheels early
Made some name plates for under my switches etc, there getting anodised then I will engrave them up
The next job took me almost two full days! The bulkhead, took a shot to prove I don't use cnc for everything
My Build Thread
Old 23rd January 2016, 08:17 PM
I've done it in two parts so I can get behind the dash easily
Inspection holes cut out
Left cover
My Build Thread
Both covers in place
Bit of bead rolling
Everything's going to get powder coated black
Also got my brakes all bled! Pedal feels great and no leaks so I'm well happy with that
Next job is to get that wiring sorted that I've been putting off
My Build Thread
Old 24th January 2016, 11:00 AM
Don't you just hate builds like this, you put the rest of us to shame.
I had the same idea about using a bike fuel cap and making a combined backing plate with a filler neck seeing as you can pick them up new for £15. I've been looking around and even the cheap ali aero items are £70-90.
Old 24th January 2016, 07:10 PM
Haha cheers, I will take that as a complement!
Yeah this cap came with the engine, took a bit of working out as I never had a tank neck to measure, it's real nice OEM quality too!
My Build Thread
Was on my lathe at 6am today
Turned this up to fit the drinks bottle, bit of screw cutting to
Filter pressed on top
Then on my dads cnc for a few brackets
Bracket bent and tank in place
My Build Thread
