Old 27th March 2016, 10:13 PM
Ianr Ianr is offline
the MX5 is very easy to strip if you take the body off. can't remember exactly but its only a few bolts front and rear and you can lift the shell off. Makes it very easy to get at all the bits you want. the shell has a lot of useful bits, wiring loom, ECU etc so label everything as you take it apart, its a pain to work out what goes where afterwards. Good luck and enjoy it!
Old 28th March 2016, 07:45 AM
Richard Dryden Richard Dryden is offline
Thumbs up good luck
Welcome, good luck and enjoy it.
Richard
Just keep going we will get there in the end.
Old 5th April 2016, 05:55 PM
Dave F's Avatar
Dave F Dave F is offline
Default Progress today
Well been busy today,
1. I’ve ordered my chassis, Phil you should have my order.
2. I started stripping my donor, Got the whole loom out, The loom didn’t worry me as I like to think I’m quite good at electrics, it worries me now, there’s a bloody lot of it and some of it needs rewiring, that’s in a box in the back of the garage and I’m going down the ‘out of sight out of mind’ route till I decide to grow a pair and tackle it.
Steering column is out and I’ve disconnected most of the things around the engine, managed to snap my breaker bar trying to crack off one of the rear hub nuts, so ordered another and all on hold till that comes, a bonus was brand new hubs on the front so no need to replace them. All that’s left to do before lifting the body off is cut the break lines, disconnect the clutch, undo all the nuts/bolts holding the PPF to the shell and I’m away, that should be all done in the next few days.
Now for the questions:
1. Do I need the break servo?
2. Do I use the Pedals?
3. Do I just cut the break lines as I’m not using them or shall I disconnect properly?
4. How do I drain the petrol out of the tank, probably about £10's worth in it?
5. Any further advice?
God loves a trier
Actual cost so far = Have chosen to stop counting incase I incriminate myself -
Cost ive told the wife = A hell of a lot less than I have spent. -
Old 5th April 2016, 06:19 PM
vmax1974's Avatar
vmax1974 vmax1974 is offline
1 no just the cylinder and reservoir
2 no not at all keep any clevises they may come in handy
3 just cut them off
4 I just syphoned it out after taking the top off
5 erm......apply heat to the rear hubs and try and break off the rear lower outer long nut cause bet what you like at least one is siezed solid
Old 5th April 2016, 08:53 PM
Dave F's Avatar
3 just cut them off
Thanks Vmax, I will bin the servo and pedals then. All the nuts and bolts have come off very easly so far so the law of sod dictates the last one will be siezed solid and will take hours to get off.
On another note Vmax, I have just won your bonnet on eBay. A little premature I know but as my finances are limited my body work will be made up of seconds so I will snap them up as and when they come available.
God loves a trier
Old 11th April 2016, 03:49 PM
Dave F's Avatar
Default Body Off
Body is off the donor and the rear end is dismantled, front uprights off and rest of loom, all that s left now is to get the engine off the front sub frame and that will be it done.
Could do with some advice on getting the rear half shafts out of the hub, I was all smug because the infamous bottom hub bolts came off with nothing more than a 750mm breaker bar and some WD40 but I can’t get the half shafts out of the hub, I wacked it good and proper and neither budged, I have removed the whole upright and tuned it up and filled the void with WD40, going to keep topping it up and hopefully that will do the trick.
http://s765.photobucket.com/user/dav...tml?sort=3&o=2
http://s765.photobucket.com/user/dav...tml?sort=3&o=0
God loves a trier
Old 13th April 2016, 08:26 AM
Check the condition of the crankshaft nose and pulley they are a common fault on the early engines.
Old 13th April 2016, 09:06 AM
I have used the servo and pedals on mine. I cut a section of bulkhead out around the throttle, brake clutch area and welded it to my car making a box frame around it all for support, all seems to work well.
Old 13th April 2016, 09:41 AM
Dave F's Avatar
I think it is OK as it is the long nose engine but will check it when I strip it back
God loves a trier
Old 13th April 2016, 09:44 AM
Dave F's Avatar
My shell has gone now so can't cut anything out, I did see a car, yours I believe, with the servo so have kept it to see if I can get it to fit, kind of like the idea of having good brakes but I'm not even sure if it's needed.
God loves a trier
