Old 6th May 2016, 08:32 PM
Rosco Rosco is offline
Haha cheers guys, we will see how it goes, hoping to get the wiring finished this weekend and get her running again
My Build Thread
Old 21st May 2016, 07:56 PM
Right, had a few weeks off the car due to one thing and the other but had a good day today
Got the springs back on the shocks and the ride height set roughly, it's getting corner weighted when it's finished
Everything on the rear tightened up, then got the rear tub fitted, the arches and the boot lid fitted
Well happy with it all to be honist, just need a few more black bolts
Pretty much all the wiring is finished and working now, just got to sort the front side repeaters, hopefully tomorrow's job
My Build Thread
Old 23rd May 2016, 07:43 PM
Sunday's progress
Locating pins finally fitted in the nose cone, I will get another shot when the bonnets next on
Side repeater wire extended, and hole drilled in arches, I just used a drill to twist two wires together, turned out quite neat
Wire tiger sealed to the underside of the arch, it will become clearer once the arches are back on the car I hope!
My Build Thread
Old 26th May 2016, 08:03 PM
Little mid week update
Made a spanner to tighten up my headlights
Front arches stone chipped and trim glued on
Side led repeaters
Shot of the engine bay as it's looking nice now
My Build Thread
Old 27th May 2016, 08:00 AM
Getting there. I really cant wait to see this one the road.
https://haynes.co.uk/forums/showthre...736#post103736
Old 28th May 2016, 08:52 PM
Had a good day today, got loads of bits sorted,
I needed to calibrate my water temp sensor to my digi dash as I used the bike sensor, so I got the engine running and with every 10deg c of water temp I noted down the output voltage of the sensor then, entered the figures into the dash and jobs a goodun!
Also plunged the laptop into the power commander, pretty cool, tells you rpm etc, but turned out the rpm on the digi dash was reading double, so sorted that.
Then worked out how many pulses per mile the speed sensor will read and sorted that,
Next job, the front arches, I got them fitted and wired in,
I ran the wires down the wing stay and up the brake pipe, it looks ok, not totally happy with it but it does the job,
Also one of my rear copper brake pipes was leaking, took it off and it looked fine so nipped it up a bit tighter and seems ok now, I've had the pedal wedged all day under pressure to!
Oh also I wanted an led to say the hazards are switched on, but a little harder than I thought as it also lit up when the indicators are switched on, but bit of research and I've used a diode, which is like a one way valve, so that's now working to
Got a few more bits and bobs to do tomorrow and I think it will be about finished, hoping to take her for a spin next weekend
My Build Thread
Old 29th May 2016, 08:20 AM
garyt garyt is offline
yeah that's a good days work as it is all the wee jobs that you think "that won't take long" that add up, great work and you will soon be there.
Old 29th May 2016, 08:55 PM
Well didn't get much done today, but I did roll her out of the garage for the first time and gave the garage a good clean out
See how tomorrow goes!!
My Build Thread
Old 30th May 2016, 07:45 PM
Right all day again today, and I'm still not in the dog house!
Cat fitted
Heat wrapped to cover any sharp edges
Rear view mirror trimmed up
Front sharp edges sorted
My Build Thread
Old 30th May 2016, 07:47 PM
Bit of edge trim on the exhaust can
Then some pictures with the bonnet on
Just need to trim that filter hole
My Build Thread
