Old 20th September 2016, 07:33 PM
garyt garyt is offline
oh and while I am on a roll here delving through my build pics one thing that my iva tester said he would liked a bit better was the lower seat belt mounts I did them as per the book , he said a couple of webs across the tube on each end of the plate would have been better nut he was still happy and passed them.
take loads of pics along the way of unaccesabile areas , I have heaps of them lol they will be needed later on .
Old 20th September 2016, 08:14 PM
chris_smith chris_smith is offline
thanks garyt ill bear that in mind
Old 22nd September 2016, 09:46 AM
I did that,make the plate longer and fold ends and add more weld.
Old 24th September 2016, 06:20 PM
hi everyone, so another weekend has arrived, I started by moving the upright as per previous posts.
then added all the diagonals.
I then had the tedious task of removing the diff bolts that hold the PFF on, my word that took for ever with a lot of help from "Harry Hot Spanner"
then set about the rear diff cage
Old 24th September 2016, 06:37 PM
that's good progress your making there, keep up the good work and yes there are a few stubborn bolts to get through
Old 2nd October 2016, 06:46 PM
more progress over last couple of days -
didnt have any 3mm plate for rear shock top assembly, so I put together my own using what I had lying around, will be a little bit more substantial
tunnel literally finished too
Old 2nd October 2016, 06:47 PM
Old 2nd October 2016, 08:34 PM
Great to see you getting on , good work
Old 15th October 2016, 07:28 PM
spent a few hours today fully welding the chassis, still have the rear panel supports to sort but need my rear panel to do that effectively, so set about sorting the steering column -
Old 16th October 2016, 07:14 PM
Great to see some more done something to think about now as well is what are you doing re the roll bar? More specifically the rear braces I copied a previous idea and put 2 wishbone brackets on the back edge of the diff mount plates pictures in my build or I can post them if you want to look. Others have taken them down to the rear corners at the bottom of the rear panel
Anyway great work keep going
