Old 24th April 2017, 12:09 PM
garyt garyt is offline
the last one shows the first try and I tried just about every method of bleeding the brakes and nothing grrrr went remote and bingo so much easier when the reservoir is higher than the calipers I don't have a pic of the reservoir position but will get one at the garage tonight
Old 24th April 2017, 12:45 PM
Dave F's Avatar
Dave F Dave F is offline
Thanks for that, defiantly going remote now. I have noticed that you clutch and slave is connected with copper, is that ok as I was going to go flexi?
God loves a trier
Actual cost so far = Have chosen to stop counting incase I incriminate myself -
Cost ive told the wife = A hell of a lot less than I have spent. -
Old 24th April 2017, 07:05 PM
Yes no problems with the clutch side although I left a coil in the pipe to give a little spring the movement at the bottom of the engine box is negligible
Old 24th April 2017, 07:26 PM
Dave F's Avatar
Sounds like a plan to me.
God loves a trier
Old 25th April 2017, 09:51 PM
Cropper Cropper is offline
Hi. If you check out my video you can see how I did my brake & clutch, both systems working fine, brake switch is hydraulic with no lag. Hope it helps.
https://www.flickr.com/gp/136904711@N05/g17743
Cheers Neil
Old 25th April 2017, 10:09 PM
Dave F's Avatar
Cheers Neil
Thanks for that, I see you've used copper for the clutch as well. Also liked the 'dropped' accelerator cable bracket, that will be seen on mine, that's on hell of a finish on the rockers and inlet. Nice video.
God loves a trier
Old 25th April 2017, 10:23 PM
Thanks, the throttle cable holder on the engine has since been replaced by a smaller diameter version to reduce throttle pedal travel
Old 25th April 2017, 10:26 PM
https://www.flickr.com/photos/136904.../shares/50ZQ59
This is the smaller throttle mod
Old 26th April 2017, 06:21 AM
Dave F's Avatar
I have seen that on some other of your posts and have every intention of making one, I however don't have the skill or the machinery so will have to worry about that further down the line.
God loves a trier
