Old 17th June 2017, 07:48 AM
Default Sumarise Where Your at...
So I thought this may generate some discussion.
Q1) How far along are you
Q2) How long since you last worked on the car
Q3) What are the major items to do
Q4) Whats holding you up
Q1) My chassis is fully trial fitted up and rolling, all the body work is mostly trial fitted and the seats have been test fitted. The dash was built including an ACEWELL cluster.
The 1.8CVH engine is in and has been run, the gearbox and prop are also in place although the rear gearbox mount needs finishing.
Rear lights are all done the mount for one front is 80% done.
Q2) November 2014 I think.
Q3)
Wiring.
Brakes
Roll Hoop
Cooling
Final strip and reassembly
Q4)
Stalled at doing the wiring, It's not that much of a job except when it comes to the dash which I think I counted 20+ wires to cram sort at the junction box. Since then Just been busy with other things and the garage has become an utter TIP!!
Old 17th June 2017, 08:49 AM
garyt garyt is offline
Ok here we go;
Q1; finished and on the road, well they are never really finished .....
Q2; always tinkering, just can't leave well alone
Q3; new build.... ooo arhhh
Q4; more funds lol
Seriously it was great building her and really enjoy driving her got tyres and handling and performance sorted but have started fiddling so looking to build something again , there are more ideas in my head lol
Old 17th June 2017, 11:08 AM
garyout garyout is offline
Well!!!!
Q1 chassis all welded, seats fitted (Trial) engine, box and diff in, column in rad in was playing with pedal set up.
Q2 couple of months ago due to the hassle with panel supplies I have fallen out of bed with it shut the door and trying to forget about it
Q3 Everything
Q4 Funds!! Time!! a few hours in the week less so I don't make my boss so rich
Old 17th June 2017, 11:18 AM
Dave F's Avatar
Dave F Dave F is offline
Q1) Rolling Chassis, engine in (temporarily) pedalbox just about completed
Q2) Did 3 hours Wednesday, 4 hours the week before, that was after a 3 month break #revitalised.
Q3) in order (maybe some overlap):
1. Fuel - tank fitting, copper, filter, rubber.
2. Engine - removal, Timing belt, water pump, some gaskets, painting, refitting
3. Brakes - copper, flexi's, handbrake cable securing
4. Cooling - Radiator, expansion bottle, pipes
5. Wiring - test while complete, remove redundant circuits, retest, fix inevitable problems, tidy up.
6. Bodywork - Trail fit, lights, remove, paint, refit, then drop something on my nice fresh body work - swear.
Q4) wife, Silly season at work, kids, wife, money, wife, time, kids
God loves a trier
Actual cost so far = Have chosen to stop counting incase I incriminate myself -
Cost ive told the wife = A hell of a lot less than I have spent. -
Old 17th June 2017, 04:34 PM
Ianr Ianr is offline
Q1 Car built and IVA'd and on the road
Q2 About two weeks ago but...
Q3 - car will never be finished - hope to improve braking, mainly at the rear and get the balance better, then screen er wipers, sidescreens and half hood, then improve the cooling pipe routing so I can actually get at them. Then...
Oh and I've started gathering parts for my next build - a Midlana.
Q4 got to finish a house extension I started last September - then money
You would never believe this was my fourth car build - the first 3 were all before I was 21 and I am now an OAP (the middle years were taken up with work which I think is much over rated :-) )
Old 19th June 2017, 07:37 PM
Q1) 4 years and 1 month on the road, 11300 km on the odometer.
Q2) I made a cone catcher about 4 weeks ago. It bolts to the bottom of the floor in front of the rear arches: https://goo.gl/photos/q95QWWqJZ8PPH7UE9 . Then a couple of days later I had to redo the alternator bracket AGAIN, cause the damn thing fell out after a sprint recon lap. https://youtu.be/vWEVcmj-dZE?t=3m56s
Q3) I have 2 conflicting directions: making the car more roadable and swapping ST170 on bike throttles in. Re roadability, greasing the PU bushings had an immense effect on the cars' ability to soak up road imperfections, but it only held for about a year and a half or so. But removing and greasing all the wishbones and bushings is a chore, so it doesn't get done. The other things are ordering a bigger silencer, as the exhaust noise really makes the head buzz after an hour of driving or so. Also, sidescreens should help a lot with wind buffetting. I have the steel frames done and one of them even has hinges mounted!
Re. ST170, I'm in the middle of lowering the sump since last spring or so, and I started mounting the GSXR750 throttles with 3d printed nylon adapters and trumpets this spring.
Q4) Mostly laziness and other hobbies.
Old 25th June 2017, 09:34 AM
norton norton is offline
Q1) I think about halfway. I've broken the back of the major components though and now its bodywork, electrical and mechanical refinements.
Q2) Yesterday, sanding down some rear arches prior to polishing or more likely painting/wrapping.
Q3) The nose, bonnet and scuttle/dash, electrics and getting it running with a Megasquirt ECU.
Q4) A lack of money and time however I'm due to make my own scuttle and bonnet which will take some time to get perfect so will bridge the gap before more purchases can be made. I've never liked the idea of a fibreglass bonnet, I'd want to see metal when lifting the bonnet plus I want Caterham style louvres!
Old 25th June 2017, 08:12 PM
tkpm tkpm is offline
Q1 - Nearing the end of the build.
Q2 - It's about 2 months since I worked on the roadster.
Q3 - I have to wire up all my gauges and sort a headlamp issue and get my wheel alignment set up done and final engine tune up and brake balance tested.
Q4 - Hopefully nothing now, as I've taken a weeks holiday to get everything done except the engine tune up.
Old 26th June 2017, 12:13 PM
Eternal Eternal is offline
Q1) How far along are you:
Mechanically almost finished. Will be starting bodywork once brakes are finished.
Q2) How long since you last worked on the car:
1 month
Q3) What are the major items to do:
All bodywork, brake system, steering system finish
Q4) Whats holding you up:
Time and money
Skyline Roadster
Old 24th July 2017, 05:42 PM
MikeB MikeB is offline
Nearly ready for IVA
last month
Small tidying, IVA trim, New Exhaust Link Pipe
Time
20170507_123250 by mjb22001, on Flickr
