Old 26th July 2017, 12:07 PM
garyt garyt is offline
Sounds good
Hazards permanent + as must operate with ignition off and fog light +feed from the dipped head light terminal
Old 26th July 2017, 03:43 PM
norton norton is offline
Great stuff thank you again!
Old 6th August 2017, 06:59 PM
Bonnet and an aero screen fitted!
Old 6th August 2017, 09:34 PM
garyout garyout is offline
She's looking mighty fine really nice tidy build mate you must be really happy with it.
Gary
Old 7th August 2017, 06:37 PM
Thanks Gary, yes I'm getting happier with as each new bit goes on.
Does anyone know if Caterham rear wings/arches have the same mounting flange dimensions as the Haynes arches?
Old 10th August 2017, 09:16 PM
So my nice shiny new shocks arrived today which means I can set the geometry up a lot better and hopefully get my head around bump steer.
This brought back an issue I identified a while ago with my rear uprights and their upper bushes. My poly bushes are incredibly stiff when everything is done up tight. By tight I mean I can stand on the hub with no shock fitted and can't budge it downwards at all. With its bolt slackened off all is well so I might look for a better bush if anyone has any suggestions?
I also can't tell you how relieved I was to find my shocks mounts all line up!
Old 10th August 2017, 10:02 PM
Evening mate
Is it the bush in the hub nipping up? I know Talon does a bush for the hub I got a pair for mine not fitted yet though.
Gary
Old 10th August 2017, 10:05 PM
They're the ones I have
Old 11th August 2017, 08:38 AM
That don't give me much hope although I can't see me being anywhere close anytime soon
Gary
Old 11th August 2017, 07:34 PM
Well I've ordered a different make but failing that I may turn some up from Delrin.
